Question about Garden
I have 2 year Troy Bilt 20240 PW. The motor runs
I have 2 year Troy Bilt 20240 PW. The motor runs starts and runs fine and it was working fine a week ago but now the pressure stays low and the pump won't kick into high pressure. Any ideas?
4 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
  • 6468 Answers
SOURCE: troy bilt want pump
sounds like theres a stuck valve in the pump
Posted on Mar 30, 2012
  • 6468 Answers
SOURCE: Ihave a Troy bilt pressure washer starts fine will not stay running unless I keek my hand on the handle
the pressure relief valve is stuck take it apart and clean it
Posted on Aug 28, 2012
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
Troy bilt self propelled mower overheats
Check oil level . Dump out old oil and fill with new 30w oil.
Sep 24, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Model TB110 rand great first few times but will not run now. Cranks but run rough and dies. Only had 6 weeks. Lowes say they can't help me and I just need to have it serviced! After 6 weeks? Give me...
My name is Dane. Troy-Bilt says this mower has a 2 year warranty with a briggs engine. According to troy bilt, that engine is suppose to start in 2 pulls or they fix it for free. Take it to a local briggs dealer and get them to look at it. I would hate to have you try something and you void your warrenty somehow. Here's the link to the website.
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_1410819_54968_-1
Hope this helps you... Thanks....Dane
Dec 02, 2010 | Troy Garden
Pony size Troy-Bilt 30 years old\r\nQuestion; Can motor be replaced?
Yes but unless you purchase a engine with the two shafts, one for forward and one for reverse, you will lose your reverse. If you don't mind not having a reverse just go to a nearby Harbor Freight store or order on line a Greyhound 6.5 HP engine. these are Honda clones and run great they just had a sale here in Columbia Mo. and it was on sale for $99.99. I have used these on many of the Troy Bilt Horse tillers and they work great. They have metric threads and you may not be able to use your throttle cable but for the price you can't beat it.
Frank
Oct 03, 2010 | Troy-Bilt Pony Garden Tiller
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
295 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
