Question about Whirlpool Refrigerators
Not making ice; ice appears to be stuck in maker
    Brigadier General:
  • 3,513 Answers
If I got the issue correct your whirlpool refrigerator is not making ice. I would request you to please do the following steps to resolve the issue.
Disassemble an icemaker:
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed (refer to the owner's manual for specifics).
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel (see Fixing a Refrigerator) and any fasteners that hold the inlet valve to the refrigerator.
Service the water inlet valve:
  1. Turn off the water supply at the saddle valve on the pipe.
  2. Disconnect the inlet valve from the refrigerator (see above).
  3. Unscrew the tubes from the valve, letting excess water drain into a bowl.
  4. Unplug the wires from the valve.
  5. Use a multimeter on RX10 (resistance times 10) to probe both terminals on the valve solenoid. An infinite reading means the valve solenoid is bad; a reading of 1,000 ohms or less means it is probably good.
  6. Remove the plate and filter screen from the water inlet. Wash a clogged screen with a toothbrush under running water. Replace the screen if it is rusted or damaged.
Hope this would resolve the issue:
God Bless.
Posted on Jul 11, 2009
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
Jun 14, 2017 | Kenmore Refrigerators
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Electrolux ice maker bucket stuck
Probably the ice maker leaking caused by ice maker itself or faulty water valve. I would think you would have to let Ice thaw that's most likely holding bucket from coming out and then replace Ice Maker or water valve or both.
Aug 23, 2017 | Electrolux Refrigerators
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
The ice maker has stopped making ice. There does
check the module head, the power wheel often breaks loose and the drive motor no longer is engaged, replace the module head!!
Nov 15, 2009 | Whirlpool ED5SHAXM Side by Side...
Icemaker not making ice
Sounds like you need to replace the ice maker. The mold heater appears to be defective.The mold heats up prior to a ice dump. I donot believe it is worth repairing
Sep 29, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool gd5shaxkqoo side by side ice maker
Hi. It takes approximatly 3 days to fill the ice container. If it is filling it half way, it should fill it all the way. There is no reason for it to stop making ice unless a cube gets stuck occasionally. Try replacing the water filter. If you are using reverse osmosis to filter your refrigerator water then that is your problem. Refrigerator ice makers don't work well with most reverse osmosis systems. Good luck, Mack
Aug 14, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
