Question about GPX YGBD707 7 in. Portable Television
No vidoe: The video displays on the external connection when plugged into a TV set but will not show video on the cd screen. Can you tell me what is wrong with this unit, where to get parts, or where to get it fixed. Thanks
There is a switch on the back that turhs the LCD on or off. Is it on?
Posted on Sep 09, 2009
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Hi I have a l32wd12 r a TV and it will not turn on
If the clock is on then the unit is receiving power; maybe the external input feature (which tells the TV which outside source to display on the screen, e.g. cable TV, DVD player, VCR player, etc.) is not set to display the TV channels. On my Sony TV there is a button that displays TV setting options (e.g., Favorites, TV List, External inputs and settings). The external inputs function displays the options as video 1, video 2, etc., right up to video 6. My video 3 is for the VCR, video 4 is for the DVD, and video 5 is for the cable TV channels. If the TV is set for say video 3 and nothing is playing on the VCR, the screen will be dark (almost as though the TV is off). Your solution might be as simple as choosing the right external (video) input for the TV to receive the channel signals.
Sep 19, 2014 | Televison & Video
My Settings/Advanced/Displays, don't show, there is no setting to use any ex. screens I have 2-Inspiron 8500s my other one shows the setting display but one don't can you tell me what to do to get...
LAPTOP OR NOTEBOOK COMPUTERS HAVE A KEY ON THE KEYBOARD IN THE LOWER LEFT SIDE THAT HAS A "Fn" MARKED ON IT, SHOULD BE BY THE CTRL KEY. PRESS THIS KEY ALONG WITH AN "F"KEY, NORMALY F5, ( HAS 2-BOXES WITH A DIVIDER LINE), WILL CAUSE YOUR SCREEN TO GO BLANK AS IT IS NOW SENDING THE VIDEO TO AN EXTERNAL MONITOR. PRESSING THE 2-KEYS AGAIN WILL APPLYTHE VIDEO TO BOTH MONITORS, THEN PRESSING BOTH AGAIN WILL RETURN IT TO YOUR LATOP ONLY.
Aug 24, 2011 | Dell Inspiron 8500 Notebook
Wanting to connect my Aspire One ZG5 to a television through a VGA cable. How can I do this? When I connect the lead to tv it tells me 'no signal'. Do I need to download/install anything to use...
HI, if you want to have the display show on your television, you have to configure the display settings first on the display setting on the computer. Just follow the steps : Step 1 : right click on the screen redmatrix_2.jpg
Step 2 : click on the display option
: redmatrix_3.jpg
Step 3: then check if you have an option to choose to extend the display on an external television. redmatrix_4.jpg
after getting the option, reboot the computer and the display should be showing on the television.
thank you for using fixya.
Jul 05, 2011 | Acer Aspire One PC Notebook
Connect laptop(with HDMI output) to TV( with s-video input)? Hi I have a laptop in which there is port for HDMI output and TV with S-Video input. I bought a cable (HDMI HDTV to VGA HD15 Y/Pb/Pr 3 RCA...
Here how you can connect a computer running windows vista to projector or other external display.
  1. Open Personalization window by right clicking on empty desktop and choose "Personalize",
  2. In the Tasks list click on "Connect to a projector or other external display" link,
  3. The Windows Mobility Center appears, in the presentation settings box click the turn on button to turn on projector,
  4. Now your screen will show up on projector screen around large display as well as your own computer screen,
  5. If you want to change the presentation options click the Projector icon inside presentation setting box,
  6. The Presentation Settings Windows appears, if you turned on the projector the "I am currently giving a presentation" checkbox is selected,
  7. When you are giving a presentation your computer stays awake, system notification are turned off and by default the screensaver is turned off,
  8. You can also set the system volume to show different windows wallpaper in the one you usually use, when the presentation ends and you turn off the projector your regular desktop wallpapers returns,
  9. If you are not sure what displays are connected click "Connected displays..." button on bottom of existing window.
Jan 10, 2010 | Office Equipment & Supplies
CONVERT MY LABTOP HP DV4000 TO PAL TO CONNECT IT TO TV PANASONIC, MALAYSIA
Your model type has an S-Video output on the right side or the same side as the CD/DVD-Rom Drive. It should be located in-between the lock point and the external monitor port:http://www.notebookreview.com/assets/4611.jpg
You need an S-Video cable and a TV with an S-Video input, usually on the back of the TV.
If your TV doesn't have an S-Video input then you need an S-Video to RCA adapter like this one:http://www.datapro.net/images/1161-FF.jpg
Plus one male to male RCA video cable
or an S-Video cable to RCA:http://www.preisvergleich.org/pimages/Verbindungskabel-S-Video-Video-Stecker-Cinch_164__hm-00042742_40.jpg
After you have all that connected, you have to load up your display settings and set up the TV as an external display. If your tv flickers but still stays black try and set the display of your laptop to 800 x 600 or 1024 x 768, anything higher might not display on the TV. Also make sure your video settings output the correct display on the TV; NTSC or PAL depending on your location.
and for sound
you need one of these:http://www.frontx.com/pro/c216_042p2.gif
AUDIO RCA to Stereo, conect the stereo audio jack to the laptop and the two RCA connectors to the tv.
Nov 28, 2009 | HP PAVILION DV4000 SERIES 100GB HARD DRIVE...
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Cant get compaq laptop to show screen on TV with cord
Well, my wife has an older Compaq Presario so I don't know if this solution will help...
After you connect the cabble from the laptop to the TV, you need to tell the laptop to send a TV signal...
On her laptop, there is a special "FN" key on the keyboard near the "Windows" key. You press that along with the display key at the same time. Her display key if the 'f4' key at the top of the keyboard.
It is likely that you'll need to do the same thing with your system.
The only other way would be through the display properties setting.
With ALL windows closed or minimized, right click on an empty area (no icons) of your desktop.
Select the Graphics Properties option and look for a multi-display option or an option to change display devices.
Should say something like TV, S-Video, Composite, or maybe HDMI.
Hope this helps,
vujsa
Jan 11, 2009 | Compaq Presario Notebook
Connecting Laptop to LCD
VGA cable doesn't carry any audio: use your audio output from PC into TV audio Input (standard RCA).
You need to configure your Display Properties to manage TV screen to get an effective connection.
Either you have a generic Video Grafic Driver add on (I'm using Intel Graphic accelerator) on your display properties either you are using a specific (NVIDIA) driver for your video card.
To check go to CP/ Display, settings Tab and in advanced you should be able to check your choice (if you don't want to go to user manual.
You can also (in CP/ Display, Settings tab configure TV as a monitor and select your option accordingly: use screen resolution on screen # 2 not over native resolution of your VIZIO screen (1080 x 960?) and be sure to use all the parameters as TV can accept.
As soon as TV is configured as per resolution and refresh etc..
check the presentation function on your PC: it's normally a FN key showing a screen icon on key top (on my Acer travelmate is FN + F5) on aspire may be it's FN + F4.
This function key will circle between: PC mail screen -> External screen (as you configured on Display settings) -> both screen.
Jan 04, 2009 | Acer Aspire 3680 Laptop
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
GPX YGBD707 7 in. Portable Television Logo
46 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Damen Wong
Damen Wong
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
