SOURCE: The iron leaks from the base when at rest (up
THAT SHOULD HAVE A WARRANTY. SEE THE STORE MGR. WHERE YOU PURCHASED IT.
SOURCE: swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
SOURCE: Shark Intelligent Electronic Iron - how to clean the soleplate?
Try a "magic eraser". They're minimally abrasive. Then run the iron over a piece of waxed paper and then on a cotton cloth or rag.
SOURCE: Hi my swan steam gen iron is faulty , when I press
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
God bless you
