Tablets & eReaders Logo
Nathan Burnell Posted on Jul 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset password on bauhn sphere tablet - Tablets & eReaders
De ice
Level 3:
Diehard:
Visited the website for 60 consecutive days.
  • Tablets & eR... Master 711 Answers
  • Posted on Jul 01, 2015
De ice
Level 3:
Diehard:
Answers
711
Questions
Helped
175544
Points
3800
I've forgotten my password on my bauhn AT-HK97 what do i do
Factory reset to wipe all user data including passwords
hope you did a recent back up of data to reinsert after wiping
Bauhn tablet frozen
all android tablets are the same to reset
if doesn't reset need to download os and flash image
How to reset password on bauhn android tablet
In the back of the hand book there is a section called firmware reset just follow the instructions and install another password write it down this time .
How to do firmware reset on a bauhn tablet - model AT - HK8
OK THIS WORKS 100%
1.Use a pin in the rear reset hole whilst holding the power button for A-HK8 Aldi Tablets, hold until the screen flashes white once, Then turn on Power as normal....it will appear to be stuck on the ANDROID logo but it isn't....
2.wait with the android logo showing on the screen for 3 minutes, don't touch anything, just let it be for 3 minutes....
3.the upgrade or optimize app menu screen will come on, let it finish the upgrade usually 1 or 21 ..(let it do it if this comes up don't touch anything) ...if no upgrade is required, it will go straight into the screen ready mode with the clock.....
4.navigate into settings, and select backup and reset......(at this point if you have a SD card i would backup your apps and google account to it) otherwise hit erase everything.....and factory reset the
tabletTechnicians notes:
I must also say that the dual core in these HK8's get very overloaded and overheat when playing it, as there is no gills or vents on the back cover, this is a manufacture fault by Bauhn, and they have since stopped making these,
it's a shame as it will only last a short while maybe 3 months or more until you need to do a hard reset all over again, as the tablet overheats mid use and causes a corrupt shutdown and when turned on again will need another dammed hard reset.....they constantly need hard resets... if you haven't the heart to throw it in the garbage and say goodbye to your $200 then ...this is what you will have to prepare for if you continue to own it..
one good thing though, is anything you backed up like apps, google play accounts, and photos can easily be used on a new tablet say like a "samsung" if you keep getting the crash error saying " Apparently such and such stopped working" means the Core duo chip is overheating at this stage, feel the back cover its unaturally hot and your battery juice is being sucked dry. means pretty much your core duo is fried and anything you touch will stopp working, it can't run when that hot....like i said earlier this is a common fault with the AT-HK8 Tablets from ALDi...and why Bauhn quickly stopped manufacturing them and offering support any longer....believe me after hard resetting it a few times every few months, you will want to take a hammer to it or frisbee it against a wall. up to you.
1helpful
Bauhn faulty audio jack
Hi have you try different headphones? If it still don't fix the problem you need to replace that socket or if your tablet got Bluetooth use this insted. Regards
Manually reset bauhn 10.1 android tablet
Find the pin hole in back and undo a paper clip stick it in the hole for 3 sec this should do it
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
