Question about Lincoln Electric LINK2400-+1 CV-305 MIG Welder with Options Input Power: 20
Snap-on YA219 mig feeds wire & gas when trigger is depressed but no spark. I have no owner's manual or wiring scematic.
  • 850 Answers
Check the aerth [ground cable & connections]
Posted on Jul 20, 2009
Acquired snap on ya219 that didn't weld. Replaced the capacitor. Powered on and struck an arc on the the ground lead. I removed the welding wire and noticed that when the wire speed was turned all the way...
Could be a shorted output rectifier (diode). This would cause a lot of current pull, and therefore voltage drop (fan slowing down). The electrolytic capacitors are for dc voltage, and will blow with wrong polarity, which means ac voltage would be the wrong polarity half the time.
Feb 27, 2015 | Snap-On Welding Tools
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
Mig welder gas stays on all the time
Hi:
The problem must be the solenoid valve. This one must be stuck and remains open always. Dirt or metal shavings can the reason.
Change the solenoid valve.
Nov 05, 2011 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
My welder suddenly stopped feeding wire and gas when i push the trigger. i'm assuming that either there is a problem with the trigger signal or the duty cycle was exceeded. If the duty cycle was...
I found a manual that has a lot of information in it.These welders only have a duty cycle of 30% so that means you can only run them 3 minutes out of 10.They have thermo switches that shut them down before they get to hot.The house breaker needs to be around 50 amps at least I have a 125 buzz box and a wire feed and that's what I use.I would check the circuit breaker in the house to see if its tripped.I turn my mig on the side so that the shavings from the wire pushing wheels don't get pushed into the liner and clog the wire and make it jam.Well hope this helps.Thank You for choosing FixYa.com and good luck!
http://www.hobartwelders.com/service/owners-manuals/
May 15, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Feb 25, 2010 | Hobart Welding Tools
Ya219 - no spark
make sure you are getting a good ground....if thats not the problem its something inside the board that is fried
Jul 11, 2009 | Welding Tools
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Lincoln Electric LINK2400-+1 CV-305 MIG Welder with Options Input Power: 20 Logo
1,672 people viewed this question
Top Lincoln Welding Tools Experts
Greg Bernett
Greg Bernett
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
