Question about Karcher K2.26 Electric Power Washer
Need to replace broken inlet hose fitting for a K2.26m. Where can I get replacement parts?
  • firehead May 11, 2010
    You can try HERE if you are in the USA
Broken plastic water inlet connection.
I have the same problem. The design is bad with the weight of the hose and the lelength of the plastic inlet tube from the body creates a sheer force that causes it to break. I cannot find anything but a plastic inlet part. If someone would create a metal inlet connector they could make a lot of money. You need a lot of hose slack when moving your power washer or it will break off the inlet and the parts are abotu $20. Very poor design!!
May 08, 2012 | Honda Black Max 2600 PSI Pressure Washer
Leaking water on the bottom of the washer while washing. Could you please tell me what`is wrong with my washer.
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from underneath my washing machine. how do I fix it? the hose is connected properly, too
Water leakage
Sep 22, 2011 | GE Washing Machines
I have a broken plastic inlet valve for the water supply. It has standard female hose threads on one end and the same thread as the pressure hose has on the other end where can I find a replacement? It has...
May I suggest replacing this plastic part for metal parts (parts for 16 year old unit most likely not available) available thru www.pwmall.com or other pressure washer parts houses. Look thu parts listings and purchase adapters with correct thread /fitting type for your application. They will assist you with your purchase. As an example, view the following link for adapters.
http://www.pwmall.com/s-20873-twist-connect-couplings.aspx
Northern tools also has a very good selection of fittings to solve your problem (Northern tools Co are in most larger cities). www.northerntool.com
Good luck
Apr 17, 2011 | McCulloch Garden
NEED THE RUBBER PIECE FOR WATER DRANIAGE; A PLASTIC CONNECTER TO THE SCREW ON WATER EXIT HOSE FITS INTO A SOFT RUBBER INLET PORT; THE SOFT RUBBER INLET COVER HAS MELTED. I NEED A REPLACEMENT PART
I will advice you check ebay.com to search for the replacement part and order for it or you can check any electronics sales shop to get the replacement part.
Take care.
Aug 24, 2010 | Comfort-Aire BHD-501 Dehumidifier
When i set the programme to wash it only fills with a little water and then stops - not even washing
You most likely have a faulty inlet valve.
I believe in the Bosh, there is a 2way inlet valve for the cold intake and a single valve for hot water.
Remove the top panel see where the hoses connect to the back of the machine. these are your inlet valves.
You most probably need to replace the cold inlet valves.
Get the part before hand. Turn off machine from the power source. Observe the wire connection to the valve solenoids. Replace the valves and fit the hoses as they were. Take notes or pictures so that you remember how they fit.
If you have questions let me know.
regards
Ash
Nov 09, 2009 | Bosch Classixx WFL 2066 Front Load Washer
99 Chevy 1500 heater core inlet hose male fitting broke
well you may need to replace the entire heater core if the remaining inlet/outlet nipple is not long enough. common problem many people have
May 27, 2009 | 1999 Chevrolet Silverado 1500
Karcher K2.26 Electric Power Washer Logo
242 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
