SOURCE: Where is the factory amp
The amp relay is in the Relay/Fuse box located under the hood. The amp relay is the one labeled NBS which stands for Name Brand Speakers.
If you are trying to install an after market radio in a 2001 Chrysler Town and Country, you may notice that no sound comes from the speakers. This is because the single wire that is connected to the factory radio sends a signal to the Bus which tells the relay to turn on - powering the factory amp.
I bypass this by running a wire from the red Acc power wire on the radio to the relay. Connect the wire to pin number 87 on the relay. When standing in front of and facing the van, pin number 87 is the pin, on the NBS relay, which is closest to you and furtherst right.
Are you looking to replace the amplifier? or bypass the speaker wires??
Usually factory amplifiers in vans are under the P/S Front seat. However they can be up under the dash as well (P/S).
If you're looking for it because it is not turning on - check the relay (as above).
Thanks for using FixYa - a FixYa rating is appreciated!
SOURCE: Chrysler trouble code U110C on 2005 chrysler town
encrypted software ,dealer only----yes i know you are showing a reading but it doesnt mean anything or if it does it shows a different code .so your snap on or mac tools scanner is a waste of time and money.Nearly all new motors from 2005 are using encrypted software to stop general mechanics like me from working
SOURCE: chrysler town and country wiring diagram
Where is the amplifier located on a 2002 Town & Country? My stereo seems to be working, but there is no sound coming out of the speakers.
SOURCE: Trouble codes on a 2000 Chrysler town and country
0775 is Presure Control Solenoid "B", 0784 is 4-5 Shift these are trans codes from the transmission Solenoid. This is a changable part for any mech. Part is around $200 & includes the gasket.
SOURCE: 2005 town and country factory stereo removal
I found the below image to help with the faceplate removal.
http://www.pro-fit-intl.com/Adobe/DG-91-01.pdf
The factory plugs were already cut when I got the van so the adapters wont do me any good
