Question about Ovens
What is the amperage rating for the kenmore 30'' electric built-in oven model number 911.41065791 at 240volts?
  • Craig Butler
    Craig Butler May 11, 2010
    Do you know the wattage rating?
    President:
  • Ovens Master
  • 1,922 Answers
Most ovens just inside the oven door on the top edge have a metal nameplate with model# and the wattage at X# of volts,it could be on the rear but most in frt,take total wattage and devide by input (supply)voltage i.e. 240volts(example 12,000watts/240volts=50 amps)
Posted on Jul 27, 2009
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
I will soon purchase a GE Double Oven (no stove top). I need to know what amperage I need to wire my kitchen for. 30? 40? 50? thanks.
A full upright range including 4 hotplates, oven and grill elements is generally rated about 8.0 to 10.0 kilowatts. The normal circuit in Aust. is a 32 amp circuit. Check the kilowatt rating of the double oven but I don't think it will be any higher than 6.0 kilowatt. If so the 30 amp circuit will be fine.
Feb 18, 2011 | GE Profile JTP56 Electric Double Oven
The oven wont heat up and the glow plugs are working and the gas is on
Most often the problem is the ignitor is not drawing enough amps to open the safety valve. Without knowing your model # , your valve could be rated 2.5-3.0 amps or 3.2-3.6 amps. If you can access one of the wires on the ignitor , you can read with an ammeter. Proper amperage will be printed on sticker on side of valve. Be sure to replace ignitor with one of proper amperage.
Jan 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Necht model 720 built in electric oven. Fan
If the oven fan is working o/k, thenyou need to replace the fan oven element.
Please rate my solution.
Thanks.
Sep 16, 2009 | Ovens
Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Amperage on Kenmore Double Oven
30A
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2009 | Kenmore 47763 Electric Double Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Ovens Logo
110 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
