H
Holden Kaypex Posted on Jun 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for a Manual for this receiver. I can only find a Brochure online. Trying to hook up a pair of speakers to the rear channels - but getting no sound. Any Help? Thanks!
AV 1 Receiver - Looking for a Manual for this receiver. I can only find a Brochure online. Trying to hook up a pair of speakers to the rear channels - but getting no sound. Any Help? Thanks!
Frank Jesko
Level 2:
Habit-Forming:
New Friend:
  • Expert 62 Answers
  • Posted on Jun 30, 2015
 Frank Jesko
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
62
Questions
Helped
15547
Points
190
Click on this link. This link will give you many choices to get your manual. Good luck. http://snmputils.com/booksearch/nakamichi-re-2-user-guide.pdf
Testimonial: "This is a website that seems to be spam and a place to put in my credit card info - I am not looking to join or give my credit card info to a site to get a pdf or a copy of the manual!"
1helpful
Pyle PTA44BY Receiver. I can't get sound from it? I put wires in for speakers and no sound.
Question edited for clarity and typos.
The Bluetooth isn't correctly paired. You are only half connected.
https://www.fixya.com/support/r26362721-pairing_bluetooth_devices
STEPS FOR CONNECTING WITH BLUETOOTH DEVICE Once paired you can play music from your Bluetooth device. You can also use the control buttons on the unit to select the tracks from your Bluetooth device.
1. Press MODE button to choose Bluetooth mode, display BLUETOOTH on the screen.
2. Search on the Bluetooth device name from others Bluetooth device and you can and the Bluetooth name - PYLEUSA
3. Select the PYLEUSA Bluetooth name and wait for the device to pair.
4. The PTA44BT will emit a noise confirming that the devices have successfully paired..
PTA44BT
Pyle USA http://manuals.pyleusa.com > PDF > PTA44BT PDF PTA44BT. 4 Channel Audio Amplifier. Multi-Source 1/4" Audio/Microphone inputs ... PyleUSA.com ... Read these instructions thoroughly before using this item.
9 pages
PYLE PTA44BT USER MANUAL Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > ... > PTA44BT
View and Download Pyle PTA44BT user manual online. 4 Channel Audio Amplifier. PTA44BT amplifier pdf manual download.
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
I'm running two sets of speakers thru a gfs3 powered by a gfa 5300. the main speakers are on 1, the second room pair on 2. the speakers on 2 will only play when the main speakers are engaged. i recently...
Do you mean Adcom? That detail matters.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFA-5300-Car-Amplifiers-manual/id/582ci558/t/2/
That would mean you're trying to run two rooms with paired mono speakers and a different channel in each room. MMmm, okay.
It's a 2-channel power amp and it isn't really designed for the probable very low imedance you're providing with paired speakers on each terminal. And it has no ability to turn either channel on or off short of denying it a program input on either channel.
Perhaps if you ran one speaker from each channel into each room (impedance permitting), you would have two rooms with traditional 2-channel audio.
How can I hook up the speakers on my car to my stereo? Got it workin just don't know what I need to hook up the speakers?:
Most modern car stereos have 4 channels. Each channel has a pair of wires, one a solid color and one the same color with a black stripe. The solid color is positive and the black stripe is negative. The channels will be color coded white for left front, grey for right front, green for left rear and purple/violet for right rear. So you simply hook up the positive and negative wires from each speaker to its corresponding channel based on the speakers position in the car.
1helpful
No problem but ?
yes, the manual will explain how. Most cases if you do,you wil end up with 5.1 as you would use the 6th and 7th channels to get mor power to you front L/R.
I have a LG 42" LCD paired with a LG LHT854 home theater and a directv HD receiver. I the satellite receiver and 854 hooked to the TV via HDMI and the satellitle receiver is connected to the 854 via...
I have an almost exact set-up and you will only get sound out of your rear speakers when the TV channel is broadcasting in 5.1 Ch Stereo. Otherwise the sound is limited to your front, center, and woofer speakers.
Panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
7helpful
2answers
Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
INSTALLING A CD RECEIVER IN MY CAR
Some decks only give one pair of pre outs. Most 4 channel amps can use just a 2 channel input and feed the other 2 channels by the flip of an input selection switch. I recomend a 4 channel amp if you want to power front and rear speakers and be able to set the gains to blend properly, or you can run all 4 speakers at a 2 ohm stereo on 2 channels and run a sub on the remaining r channels. It just depends on how you want the setup to be nd to how much control you want. Let me know.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Top Nakamichi Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
