Question about Garden
Mower won't start. changed spark plug, filter clean
    Sergeant:
  • 227 Answers
Try removing rust from fly wheel. Next you may have a bad coil.
Mike
Posted on Jul 12, 2009
My huskee 21 173CC OHV powermore push mower starts then stops. What could be wrong? I changed the spark plug and the air filter.
Cindy, try running with gas cap off , if it runs OK then the caps vent hole is plugged, either try and clean vent hole or replace cap. It could also be a dirty carburetor which would need torn down and cleaned/rebuilt. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why Your Mower Won Start Mower Reviews Consumer Reports
Lawn Mower That Starts then Stalls
Lawn Mower Starts Then Stalls
Engine starts and then shuts down
Jun 25, 2016 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
Lawn mower won't start
Sounds like gummed up. Remove carb and filter and clean with gas. Clean all lines. Try not to use ethanol
Aug 06, 2012 | Garden
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
