Question about Radio Communications
Microphone I have a headset with 4 wires but i cant seem to get the microphone to work but i know which two wires are the ones for the microphone can u help?
  • mtt3 Dec 20, 2007
    Thanks this fixed the problem!
  • Sassy Sherry Aug 15, 2008
    i cant the the mircophone to the headset to work at all
    Brigadier General:
  • 6,966 Answers
To figure out which of the 4 wires go where, you would need access/use of a continuity tester (ohmmeter). You have to wing it from the ohmmeter reading to distinguish the ground/common, left, right and mic. Please refer to the diagram below.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 15, 2007
Does it have a microphone on it? Because I can't seem to get it to sense my voice. It only works if I plug in the annoying headset piece. Is this necessary?
Greetings - The webcam does NOT have a built in microphone. That's why the headset/microphone is provided with the unit.
You could use a different microphone or headset than the one provided, but again, the additional hardware is required for it to work.
Regards,
Mikeywaf
Jun 09, 2011 | GE 98650 Webcam
My headset microphone not working
microphone is a miniature part of the headset....it is spoiled means it cant capture the audio signals and couldnt convert into electrical signals.....it need to be replaced....nothing can be done....
dont forget to rate me....
good luck.....
Apr 15, 2010 | GE (98980) Headset
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Mar 30, 2009 | Microsoft LifeChat™ LX-3000 Headset
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Crackly Headset
Mate, im having the same Problem i have no idea what to do!
When the Red light is on, it doesnt crackle, but when the Red light is on.. i cant use it as a Microphone.
But when i turn the red Light off.. there seems to be a crackly noise everytime i speak!!
I did manage to fix it for like a day.. i just pushed all the wires and it seemed to work. but hasnt for over a month now..
Aug 16, 2008 | Microsoft LifeChat Stereo Headset with...
Dynex Earclip Headset with Noise-Canceling Microphone driver
ok umm....it is a noise canceling microphone, the earpiece works but when i talk into the microphone no one on the internet can hear me please help me with my dynex earclip headset
Aug 08, 2008 | Dynex Earclip Headset with Noise-Canceling...
My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Feb 12, 2008 | Toshiba Satellite A135 Notebook
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Micrphone doesnt work
No one hears you because your microphone is probably set on mute. Go to your start menu, then go to control Panel, find Volume and Sound Control should be the icon that looks like a speaker. Double click that icon. From there Click Options and then properties, find the Microphone option and click the box to the left. This should add Microphone to your menu, then simply unmute your microphone.
Aug 30, 2007 | Logitech 250 Headset
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Radio Communications Logo
725 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
