Question about Pioneer AVH-P4900 Car Video Player
AVH-P4900 E-Brake ByPass?
All I need is a straght answer from a Professional to bypass this E-brake gnd. Some say do nothing, some say SWITCH IT, others say connect it to a 12v+.....What's really going on. I just bought the deck, i'm not trying to blow it out......Any help is greatly appreciated. THANX
Re: AVH-P4900 E-Brake ByPass?
My name is derrick and i found out how to bypass the e brake using a relay if you need help email me at and no you don't need a switch.
Posted on Feb 29, 2008
  • 111 Answers
I have bypassed many units with an ebrake safety.. best bet would be a toggle switch, connect to ground. i don't believe your unit uses a 12v+ for the ebrake signal, but if it does, connecting the wire to ground first won't harm the unit, try it out, flip the switch on-off-on and take it for a test drive. if it works, you are good to go, if not, test it with the positive.
if you need any further help, feel free to post a followup,
Posted on Nov 18, 2007
0 characters
3 Points
Bypass video on Pioneer AVH-X6500DVD
None of the above methods will work on a newer Pioneer. You can't just ground the wire, it won't work. The wire has to see nothing on it until the radio is already on and then needs to see ground. You can do it with a switch or a relay, but just grounded it does not work.
Dec 27, 2013 | Car Video Players
Wat wire do i hook up to b able to view my movies on my pioneer avh p6500dvd
the green wire is the e brake cable if you ground this wire you can bypass the need for the e brake keep in mind that because of the type of deck you have you will need to install a switch and you will have to switch ths on and off everytime you turn into or awayfrom acc
Aug 24, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Most can be wired to an ACC power and run constantly that way.
Jan 24, 2010 | Pioneer AVH-P4100DVD Car DVD Player
Error came up while watching dvd cut off they say
error-02 is a dirty disc.
Clean disc or replace scratched disc.
Thats it
Jun 04, 2009 | Pioneer AVH-P4900 Car Video Player
Bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Mar 24, 2009 | Pioneer AVH-P4900 Car Video Player
Parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Feb 11, 2009 | Pioneer AVH-P5000D Car DVD Player
Pioneer avh-P4000-dvd
let me know if you get an answer. i have the same problem
Jul 13, 2008 | Pioneer AVIC-D3 Car DVD Player
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Pioneer AVH-P4900 Car Video Player Logo
992 people viewed this question
Top Pioneer Car Video Players Experts
Craig Sagar
Level 1 Expert
Phil Sowers
Level 1 Expert
Are you a Pioneer Car Video Player Expert? Answer questions, earn points and help others
