SOURCE: Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
SOURCE: Kitchenaid Superba
you may have a high water pressure issue or just have a water inlet vavle that is failing not completely closing after the im stops calling for water. try turning the water on/off vavle all the way off then openit just 1/4 of the way open if this solves the issue its high water pressure if it doesn't the water vavle is failing and if it is not dealt with it will damage the icemaker
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Testimonial: "thanks for the help. "
