Question about RCA P52926 52" Rear Projection Television
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
No red clor on screen can adjust red manually inside back of tv.
  • 4 Answers
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Posted on Jul 11, 2009
  • 3,741 Answers
On the back of the tv there are three spinning objects like screw for adjusting.red,blue and green colour.but by adjusting that its still not working.then its ic problem on the board.the cost of ic is near to $15.there are two ic on the board.both has to be replaced.you can get it at www.radioshack.com and the number of ic will be stk392--100/120/150. thanks.
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Monochrome picture
i would assume the red crt is bad or the red video amp is bad I would also assume you tried turning up the clor in the menu?? if it is the ube i would say no not worth fixing
Dec 02, 2009 | RCA P52937 52" Rear Projection Television
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
One bulb is too bright
there is an adjustment inside the back of the tv to turn the color down
Mar 02, 2009 | RCA P52926 52" Rear Projection Television
Rca tv screen went all red. you can still see program
Color wheel controls the color. try replacing then reindexing the color wheel. Let me know if you need further assistance.
Mar 14, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Red shadows in picture
Possible "blooming"==red CRT, adjust screen control==qualified tech only.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
Alighning tv
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
Apr 15, 2007 | RCA P52929 52" Rear Projection Television
RCA 46" Rear Projection TV - Picture is Blurry and RED
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Dec 27, 2006 | RCA P46812BL 46" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
231 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
