Question about LG RH266 Recorder
Dvd draw will not stay closed to play dvd as if open and close functions have become logically reversed
    President:
  • 625 Answers
Http://www.ifndef.altervista.org/MaterOnline/Micro_eng.zip
That is a guide to clean teh microswicthes. It will help straighten your problem back out.
Posted on Sep 19, 2009
Paeroa
  • 457 Answers
SOURCE: DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Posted on Sep 13, 2007
  • 31 Answers
SOURCE: lite on LVW 5005 NOT WORKING
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Posted on Mar 06, 2008
fieldy14
  • 456 Answers
SOURCE: LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Posted on Oct 10, 2008
  • 4234 Answers
SOURCE: dvd tray will not stay closed. opens and shuts randomly
I'm not familiar with your exact model, but usually when this happens, the loading belt is at fault. There are microswitches inside which determine the limits of the tray movement. There is one that is activated to indicate that the tray is out and another to indicate that the tray is in. If the belt slips, the inner may not be activated and the system will cause the tray to come out. Try replacing the belt.
Keep us posted.
Dan
Posted on May 12, 2009
SOURCE: lg dvd drawer opens by itself and wont stay closed
The link DOES solve the problem. Worked for me even with another LG model number not listed there. Thanks!!! :)
Posted on Jul 06, 2010
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Draw will not close
Look under the drawer and look for a plastic pin sticking up. This pin needs to be in the track on the bottom of the drawer for it to close and load correctly.
Feb 22, 2013 | Panasonic DVD-XV10 DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Game console opens and closes when it wants to
This is more than likely a faulty logic board and possibly a samsung drive??
i recommend you either swap the logic board (dont forget to get your security key) or swap the entire dvd drive for a new one (still need security key).
www.xboxrepairkit.co.uk
Sep 17, 2009 | Microsoft Xbox 360 Console
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' jay_win2002@yahoo.com .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
Playing a dvd
I'm having a similar issue....I load a DVD and the player goes thru the normal cycle and just when you think you here the DVD start to spin...is cycles again and ejects and closes half way then powers off? I took off the cover (like I know what I'm doing) and figured that the leverage gear which raises the laser to the turn pad thing isnt getting acctuated....? I cant figure out what makes that gear turn..there is nothing really toughing it gear or spring? anyways I'm looking for a solution myself.
Jan 07, 2008 | Televison & Video
Dvd player dvd-237
have you tried changing the batteries in the remote control?
Jan 06, 2008 | Harman Multimedia DVD23 DVD Player
DVD tray will not remain closed
Try this. With the tray door still open and the power on, press and hold the play button until the door closes. If you hear the disc loading the door will remain closed for play and record.
Have the same problem - works for me!
Dec 15, 2007 | iLO DVDR04
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
LG RH266 Recorder Logo
Steve Allison
Steve Allison
