Question about GPS
Image was working in one vehicle. I unplugged the machine and when I plugged it into my vehicle there was only the blue screen. The unit turns on and off okay.
  • bill390 Jul 11, 2009
    Garmin Nuvi 360
    Thanks for the help. using the reset did fix the problem
  • 13,433 Answers
Please include the brand and model.
Posted on Jul 11, 2009
  • Ekse Jul 11, 2009
    So you don't get image, well first try the reset button below the antenna on the back that opens up.
    if the problem is still there, run the web updater
    http://www8.garmin.com/products/webupdat...
    Update / restore the unit to the latest software available.
I turned on my machine--the sewing light and screen came on, but screen is just blue. Is there a way to reset the sewing computer, or should this go to a dealer
Tracey, unplug machine and re plug to reset, and try machine.
If this does not do it, a technician will have to look at it.
press the helpful button
Feb 07, 2016 | Sewing Machines
Dryer will not start
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
My blue ray player continues to say "please wait"
My blue ray player is having the same issue. I called the LG support tech and these are the instructions I got.
1) turn power off
2) unplug the machine from the outlet and leave it unplugged for 10 to 15 minutes
3) after waiting 10 to 15 minutes and with the machine still unplugged from the wall, hold the power button on the machine down for 20 seconds
4) plug in and turn power back on
If this does not work, unit is defective and would need to be returned for repairs.
Nov 29, 2010 | LG LHB335 Theater System
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Jun 16, 2008 | Sharper Image SA260 CD Shelf System
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
GPS Logo
22 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
