Question about HP A6795A#0D1 Network Adapter
My DV6000 stopped recognising any wireless netwrorks ( I have 2+ neighboors'). The wireless adaptor light is red.
    Problem Solver:
  • 20 Answers
Click start, then type cmd into the run box.
When command prompt window opens type
"ping 127.0.0.1"
Now if the ping failed - your adapter is dead-sorry
If it comes back without packets lost - adapter is fine and your neighbors are onto you (just jocking) adapter is fine and there maybe another hundred reasons , but they all have to do with networks.
Posted on Jul 11, 2009
    Problem Solver:
  • 12 Answers
This is another problem with these models covered by the extended service enhancement. It is likely the motherboard. There is a small chance that it is the wireless card as well. You can try getting hp to cover it if your laptop qualifies via the link below. Otherwise you can send it in for service to a repair facility that does board level work.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Posted on Jul 26, 2009
Wireless problems on but light wont turn blue tried above solution pass words wont work so now what
Dear i have send some information of your problem.
Please read this and solve your problem.
Thanks.
Solution for HP dv6000 wireless problem. Fix it yourself.
Hi...
I am from Costa Rica and my hp dv6000 had a wireless problem just like everybody.
Because I am in Costa Rica, the HP FEDEX service for repair, does not apply for me.
This is the solution that worked for me.
Difficulty: easy for skilled people, medium for inexperienced people.
It is not risky but be common-sense careful.
1- Unplug the Power cable and take off the battery.
2- Unscrew the memory cover. It is the one placed in the middle (2 screws).
3- You will see the memory, the bios backup battery and the wireless card (the one that has 2 cables plugged: one white and the other black, those are the wireless antenna).
4- Carefully unplug the backup battery. Small coin-like battery with a white plug.
5- Carefully unscrew the wireless card and remove it from the card slot.
6- Unplug the antenna cables.
7- Wait 5 minutes.
8- Plug the power cable and turn on the computer. Then wait for the screen to ask you something and choose the F1 option by pressing it.
9- Wait for windows to load and shut down the computer. Unplug the power cable.
10- Now plug back the battery and the wireless card. No need to explain how.
11- Put covers back and screw, of course.
12- Turn on your computer and verify the wireless switch is on the on position, otherwise turn it on when Windows is already loaded. The blue light should be on. If not, go to Control Panel, Device manager and check that your wireless adaptor is present and drivers are properly installed.
13- Your wireless must be alive and functioning.
14- If wireless not present, then it did not work, if it is present but have some problems, reinstall wireless card drivers and do what it should be done when updating drivers. That is a different problem.
That’s it. However if you want to know some important details, read the following.
-I tested my HP dv6000 wireless card on an Acer pc that is compatible with the wireless card.
-I try to test back the HP dv6000 pc using the Acer PC wireless card and the HP system said WIRELESS CARD NO COMPATIBLE CHANGE IT.
-The only one way to reset BIOS is by unplugging the backup (BIOS) battery as explained above.
-People generally try to fix it by recovering the original pre installed system, but it would fail must of the times.
-It is possible that the Wireless adaptor is defective; in that case none of the steps above will work.
Hope it worked for you...
Mar 02, 2010 | HP Pavilion dv9000z Notebook
Ive just got an xbox 360 adaptor for xbox live and the light is still on red on the back of the xbox live adaptor, how do you get it to a green light beacuse ive tried everything. many thanks cameron
You need to first set up your connection...the red light indicates there is no connection....you need to make sure your internet has a wireless network and u need to selct ur network from ur network settings in xbox360.
Mar 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a persistent red light on the wireless adaptor, but the xbox is not recognising that it is plugged in. There is no option for the xbox to search for a network
Blinking green means initializing, steady green means it's found a wireless access point and connected.
Steady red means it's looking for a wireless network (wireless access point) which means you have to configure your SOHO router with an SSID that's broadcast so the wireless xbox NIC can find it.
I think you may have confused a comment I made - the xbox can be connected to your SOHO router by either a WIRE (ethernet cable) OR Wireless NIC (network interface card). If you're using one, disconnect the other!
If you have wireless enabled on your SOHO (small office home office) router then you should either use WEP or WPA for wireless security WPA-2 is recommended. This means you will have to know the key to attach to the wireless network. If someone else set it up then you will have to ask them for the key / passphrase.
Sounds like the NIC isn't the problem but the attaching to the wireless access point (WAP) is. Try www.xbox.com and search for some support regarding your situation. They have a good how to that details the installation / configuration step by step and it sounds like its one of those steps you're missing, unless I've misunderstood.
Good luck,
Feb 10, 2010 | Microsoft Wireless Network Adapter Xbox...
Ethernet adaptor driver
this is website you download it its free this is link go for it and its solve you this problem give the
http://driverscollection.com/?file_cid=399774520861f2d23855f7ee899
May 06, 2009 | HP A6795A#0D1 Network Adapter
Linksys Wireless-G Adaptor - downloaded driver but can't install
Please don't snap lol no really go to linksys.com and download all you need.RICHARDM69
Feb 04, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Wireless adaptor xbox 360
make sure that your modem acctually has wireless capability, enter a manuel ip address and gateway that should do it you can find out ur ip address and router settings at routerlogin.net and you should be connected to youre router if a username and password are required then there are websites conntaining all default passwords, most will be admin and password
Jan 18, 2009 | Microsoft Wireless Network Adapter Xbox...
HP A6795A#0D1 Network Adapter Logo
206 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
