Question about Kenmore 12102
Bobbin case When sewing bobbin thread knotts up into a big knot and also breaks thread.Could you please help me, to get this fixed. thank you,
  • 202 Answers
I'm betting that you put your bobbin in the bobbincase backwards. Hold the bobbincase between your left thumb and forefinger looking inside it. Pull the thread, the bobbin should turn clockwise, if it doesn't flip it over. And also your upper tension could be off and/or your needle isn't in right. Good Luck.
Rick
Posted on Nov 16, 2007
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
1957 Montgomery Ward Automatic Zig Zag machine...Tension is completely out of sink. Top thread cannot feed through the tension track properly and breaks when I try to sew. How can I readjust the setting. ...
Bobbin with right diameter with or without holes. The bobbin has to sit below the top of the bobbin case when it is inserted. Make sure it rotates counter clockwise when installed. If there is a peg in the center of the bobbin case then make sure the bobbin hole is big enough to rotate easily.
1. Top tension approximately four. Get a feel for this pull on your finger.
2. Now-Bobbin case has a small screw adjustment; on left probably. Adjust this to be set equally with the top tension set at four. To do this:
a. Feed thread through the spring area while the bobbin is installed.
b. Adjust pressure of screw until it is equal to the top tension set at four.
The machine can now be operated.
If the thread knot is under the fabric then tighten the top thread. Do the opposite adjustment if the knot is above the fabric. It should be in the center.
May 28, 2017 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I have a Brother Disney SE-2700 and the bottom threads knott up causing me to not be able to sew.Please help.
It sounds like it has not been correctly threaded or the tension is too tight. Check the tension discs for bits of thread that may have broken off and be causing a blockage.
Re-thread the top threads making sure the pressure foot is up before passing the thread through the tension discs!
Then check the bobbin is running correctly by pulling on the tail of the thread. The bobbin should rotate clockwise. Put the bobbin case in and make sure it is seated correctly.
If all this fails try replacing the needle. A blunt needle can cause all sorts of weird problems
Mar 24, 2011 | Brother Disney PE-400D Computerized Sewing...
The thread clicks when it goes around the bobbin and I have to stop sewing as it makes a big knot on the back of the fabric. I have cleaned out the bobbin case but it is still not sewing properly. It was...
Hello Supernana.
Check to see if you have your bobbin in upside down. If your machine requires it to unspool from one side having it spool from the other side (counter clockwise vs clockwise) can cause you problems like this. Your manual should tell the correct direction. My machine (Brother) for instance requires that the thread to pull counter clockwise direction.
Sylvia
Mar 17, 2011 | Elna Quilter's Dream 6003Q
Bobbin thread is breaking and thread is knotting up on the underside
check the bobbin case tension--turn the screw to the left to tighten ---turn the screw to the right to loosen
also check the needle to see if it's damaged
also make sure the bobbin is threaded correctly & placed correctly in bobbin case
check for lint or loose threads in bobbin area
check for warped bobbin
Sep 27, 2010 | Kenmore 756A-30BH Mechanical Sewing...
Needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
May 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread getting knotted
My machine does the same thing. Unplug the machine, and open the bobbin case. I would bet that you have "orphan" thread still sitting in the bobbin area that is bunching up the new thread.
Your bobbin area should be opened, cleaned and well oiled to ensure that no loose threads are sitting in there waiting to create "tension" with you and your machine.
I have found that when I have not cleaned out the bobbin area, there are loose threads, lint and fibers left behind from other projects that I have been working on.
Get a new can of compressed air, and blow out the lint, and left behind stuff, and see if that doesn't fix your problem. If it's been a while since you have taken it in for a "tune up", it should be done if you use your machine often. Happy Sewing!
Feb 05, 2009 | Necchi 3537 Mechanical Sewing Machine
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Kenmore 12102 Logo
49 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
