Question about Uniden BC350C Base Scanner
Radio Shack Pro-137 Unlock All Channels
I have followed all directions for unlocking all channels. I receive the message, "Unlock all CH in active banks? Yes = "E" and No = "."
When I press "E" nothing happens. Please advise.
  • 3,153 Answers
You didnt say what particular frequencies so I have included the links and info below
and will let you take it from there
Heads up that in some countries / States this can carry severe penalty.
I cannot give any direct information and it up to you to make sure you apply to the laws of your state etc
A good source of information are the two sites below
Frequencies
Scanner software
With any luck you will also find either the manual or a link to it there as well as quite a lot of other useful information that would give you guidance as to the legality
Posted on Oct 02, 2009
THAT ONLY UNLOCKS THE FREQ. THAT YOU HAVE BLOCKED
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
All channels locked out
To unlock all your channels do the following:
Press Mon/Hold, press 1, now press L/O, channel 1 is now unlocked.
Continue through the steps above until all channels are unlocked and you'll be scanning with glee.
Cheers,
Peter
Feb 09, 2013 | Radio Shack Pro-95 Handheld Scanner
I have a pro92,when I press scan it says all channels locked.How do I unlock all channels?
hi glad to be of help follow the following instructions
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.
goodluck
Mar 22, 2011 | Radio Shack Pro-95 Handheld Scanner
How do i unlock channels on my pro 97?
hi go to a desired frequency ,click on l/lo for 2sec this will unlock this channel
Feb 19, 2011 | Radio Shack Pro-97 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
All channels are locked out...
follow this link and have a look at user manual will be able to tell you how to lock and unlock channels.
http://support.radioshack.com/manuals/ome20-525.pdf
Jan 06, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
All Channels lock out
This happened to me and i reprogrammed the frequencies with programming software and all is well.
Apr 05, 2009 | Radio Shack Pro-94 Scanner
All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
Dec 09, 2007 | Radio Shack Pro-2096 Base Scanner
Uniden BC350C Base Scanner Logo
894 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Gene Pitts
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
