Question about Compaq Computers & Internet
Hi im having trouble setting up a hard drive
Hi im having trouble setting up a hard drive samsung 3290 sata pc wont notice
    Problem Solver:
  • 11 Answers
What kinda problem do you have?
-r0lfi
Posted on Jul 11, 2009
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
Acer Power F5, Set up did not find any hard disk drives installed on your computer,
Have you checked on the BIOS/CMOS Setup if the SATA is enabled? It it does not work try changing your sata cable with a good one... Good Luck.
Apr 29, 2012 | Acer Power F5 PC Desktop
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
I need some help...A friends laptop is very messed up, i need to install his SATA Hard drive on my computer. I have a SATA Hookup on it, its all hooked up, but WindowsXP is not recognizing it. My brother...
Hi
Thank you for your query
From what you are describing you are missing the SATA controller
Please do the following
1) Go to www.devicedoctor.com and download and install application
2) Once installed load up and click on begin scan
3) Once it has scanned it will probably pick up missing SATA controller and give you the option to download
4) Download the SATA controller and install
5) Reboot PC and the SATA drive should be recognised
Mar 12, 2010 | EliteGroup P4M800-M7 Motherboard
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Extremely slow transfer speeds from IDE hard drive to Sata
That causes that switching from IDE to SATA connection..youR IDE drive can be read slower than the sata due to speed compatibility. The new PC now proccess slower to old hard drive or IDE. so thats matter. i experience that also so i remove the drive after copying all the files it and i set aside for storage purpose only.
may this help,
melnavz
Feb 18, 2009 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
