Question about Goldstar Heating & Cooling
I have a Goldstar model-GP120CE and it has stoped working and P2 appears on the display. I know the collection tank is full and im supposed to drain it but what and where is the collection tank??
There is two drain plugs on the back of the unit, you will need to drain the the bottom black plug, you need something to catch the water. hope this helps
Posted on Jul 29, 2009
I have a Goldstar A/C model #GP120CE that quit cooling. I think the compressor is not working. Is it worth fixing?.
Check Thermostat setting, if its ok then make sure for compressor working or not.
Or try to change thermostat only if u r unable to get the result.
Compressor having long life its rarely being NG.
Hope your answer is completed.
May 17, 2018 | Goldstar Refrigerators
How do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
Apr 17, 2012 | Heating & Cooling
Goldstar GP120CE portable air conditioner with the E3 error
Sounds like a clogged condenser pipe which is common for portable Ac . It is usually due to the unit sitting low and collect more pollens an particles at floor level. A pipe cleaner tends to do the trick. Also insects tend to harvest inside the drain pipe
Jul 15, 2011 | Heating & Cooling
Hi I HAVE A DIMPLEX AIR-CON It was already here when I moved into this house but lately after it been for on about 5 mins it stops and it display a code of P2. I dont know how to get hold of a manual...
If your model is a portable AC unit, the P2 indicates that water needs to be drained from the tank.
Turn the unit OFF and unplug it, before draining the water from the lower tank into a shallow sided pan capable of holding at least 1 quart of water. Once it has completely drained, reinsert the drain plug, plug the unit in and turn it ON. The P2 Error Code should have disappeared. If not, press the ON/OFF button twice.
I hope this helped you.
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
Jun 24, 2011 | Goldstar Dehumidifiers
The humidifier appears to be working (with sound ) but is not collecting any water-cleaned the filter and still the same -the lit up area where it usually has the numbers is sitting at P2- I have lost the...
Alison -
A humidifier will not collect any water. A humidifier has a tank that you fill with water. The water is released / forced into dry air to make it moist, usually by a fan or ultrasonic method.
A dehumidifier has an empty tank that gets filled by the appliance extracting moisture from the air. The tank will have to be manually emptied periodically, otherwise the safety / water level switch will shut the unit off so that the tank doesn't over flow.
I suspect that you meant to say dehumidifier.. and if so, please provide the manufacturer's name and model. The "P2" indication will be difficult to interpret without knowing the manufacturer's info.
Nov 22, 2010 | Humidifiers
I purchased and LG Model# LP1010SNR on 8-3-10 at Home Depot. It was a floor model and did not come with an owners manual. It has a digital display screen. It is intended to run for several hours at a time...
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Aug 04, 2010 | LG Heating & Cooling
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
I have a Goldstar GP120CE Portable with an error code E3. What do I do to fix it.
If you have a goldstar GP120CE portable air conditioner with the E3 error and it's not under warranty you may be out of luck.When I called LG, (who owns Goldstar), they said these units are not cost effective to repair so finding a company to service them is difficult. If it were under warranty they would exchange it..
Jul 09, 2009 | Goldstar Heating & Cooling
Heating & Cooling Logo
1,254 people viewed this question
Top Goldstar Heating & Cooling Experts
John Tripp
John Tripp
Jim Goldsmith
Jim Goldsmith
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
