Question about Toro Lawn Mower With Toro Power Tools
I have a Toro Wheel horse, 13-horse Briggs & stratton and have zero spark what do I look for. I replaced the spark plug and have a full charged battery. I know little about engines so if you suggest i replace something what web site can i go to to view the part. thankyou
  • 468 Answers
Usually when you have zero spark, it's one of 3 things. Either there's a shutoff that is trying to shut it off when it's not supposed to, the coil is bad, or the flywheel key is sheared.
Posted on Feb 01, 2010
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What spark plug wrench is used to remove the spark plug on a TORO 38624w snowblower?
it is prob a 13/16 this is the most common most of the time you cannot get a wrench on a plug but a socket , if it is smaller then it is a 5/8 lefty loosie righty tighty do not over tighten the plug
Jan 20, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Toro CCR 2450, Common starting problems? Fresh gas/oil mix. Good compression. Just pulls, no pops or sputters.
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Jan 31, 2011 | Toro Lawn Mower With Toro Power Tools
24 horse brigs with 100 hrs has no fire. Help
You can take the engine shroud off and clean the magnets on the fly wheel. Also clean the two little prongs that are close to the fly wheel. They will rust up and you won't get the pulse needed for the spark plug. With the shroud off check any wires that might be damaged. Mice like to make nests in the engines and love to chew on the wires. When cleaning the fly wheel magnets use emery cloth or fine sand paper. Also check the connector that attaches to the spark plug. In you didn't replace spark plug I would suggest doing so.
Good luck. Let me know if this helps.
roundo4
Aug 15, 2009 | Briggs & Stratton Garden
Briggs & Stratton engine loses power
Hello herb1007
If it is running it would burn any oil off the top of the piston. (that got there when you tipped it). It sounds like you carburetor needs cleaning. There are sprays on the market that sometime help with this.
Jul 15, 2009 | Briggs & Stratton Garden
Toro Lawn Mower With Toro Power Tools Logo
142 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
