Question about NetGear (MA701NA) 802.11g/b Wireless Adapter
Wireless network setup
How do i get my netgear card from my laptop to my desktop to have internet access? i have the compatible wireless router with cable connection down stairs. desktop is up stairs... need help. may i have in specific details.
    Brigadier General:
  • 6,966 Answers
Re: wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 15, 2007
0 characters
3 Points
Other people can access our internet. How to make it private? We forgot our netgear password and username
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
The default login = admin
The default PW = password You can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
Aug 28, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
IP configuration address not shown. To summarise: We tried some time ago getting David's XP notebook and his Win7 desktop to share the Internet connection that his desktop has via an ADSL modem and...
Setup a new network under Control Panel > Network and Sharing Center > Setup a New connection > Setup a new Network. You need to make the Desktop as an Access point network. This will allow the Netbook to use the Desktop as a "router" and connect threw it to the internet. This is most likely the most time consuming way of doing it. The best bet would to pick up a cheap netgear or linksys router for better stability and ease of access.
Apr 13, 2011 | Trendnet NSPEED WIRELESS N PCI ADAPTER...
Am trying to access wifi but cant get true
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Feb 07, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How do I extend wireless coverage?
Extend the range of WiFi signals with Hardware If your router is placed on the ground floor of your home, the Wi-Fi signals will be very weak or may not even reach the basement computer or the printer upstairs. The situation will be no different if you work in a fairly large premises or if there are too many walls in the area.
In that case, here are some hardware device that you can consider to extend the reach of your Wi-Fi network:
wifi_repeater_thumb.jpgOption #1. You can attach a WiFi Repeater (also known as Wireless Range Expander) to your router and quickly expand the coverage of your wireless network without using any cables.
The Repeater should be placed within the range of your existing router and it will reflect the signals to other areas where the wireless reception was earlier poor (or totally absent). The Repeater can connect wirelessly to both routers and access points (see #3 below).
Option #2. (This is my current setup) You can get another wireless router and connect it to your existing router using an Ethernet cable. The advantage is that this setup comes pretty cheap and the Internet speed stays almost the same even for computers that are accessing the web via the new router.
You can get a 100 feet long Ethernet Cable (also known as Cat5 or LAN or RJ45 cable) for less than $10 and wireless routers start at $20. Here's a detailed guide on how you can connect two routers together.
Option #3. You also have the option to use an Access Point instead of a router to extend the WiFi range but that's often not required because Wireless Access Points can be more expensive than equivalent routers.
The other advantage with a router is that is has extra LAN ports so, in future, you can connect more wired computers for sharing files or you Internet connection.
Option #4. If you have an old desktop or laptop computer, you should consider adding an external (USB based) wireless adapter or upgrade the internal network card to improve the wireless reception (and thus Internet speed).
Jan 04, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Help wireless usb adapter connected to my computer but will not connect to the internet. i have got a wireless broadband box with sky it would be great if you could help me many thanks
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router
Nov 27, 2009 | Belkin Network & Wireless Adapters
Belkin Notebook card and its wireless access point
In Ideal scenarios, you should just plug in the card in the notebook and it should get installed automatically.
Thanyou may scan for the available networks and you should be able to seethe network of your Netgear router(Assuming that the Netgear you havementioned is wireless capable and configured).
You can connect to the network and it should work fine.
Check this link
Let me know what happens.
Jul 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless connection problem. laptop ip address is 60.60.x.x
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Is the wireless enabled for your router? Try typing and use the default password to access your router settings. Check if wireless is enabled, SSID is broadcasted, and security is off or properly configured.
Jan 26, 2008 | Network & Wireless Adapters
Getting setup
Unless you get into the configuration of the router, you don't have to worry about 'messing' anything up... you just need to know the SSID (the name of the wifi connection they configured) and the password, if it is protected with WEP or WAP... just install the card into the laptop with the proper drivers, and use either the utility that came with the laptop (turn off the Windows Wireless Config in your services.msc) or use Windows Wireless Config Utility to access (find) the SSID of her router..
Let us know if you need further info...
Nov 20, 2007 | NetGear (IM-WG511T) Wireless Adapter
NetGear (MA701NA) 802.11g/b Wireless Adapter Logo
249 people viewed this question
Top NetGear Network & Wireless Adapters Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you a NetGear Network and Wireless Adapter Expert? Answer questions, earn points and help others
