Question about Bowflex Treadclimber
After approx. 30 min. of walking on full speed it
Model: Bowflex TC-5000
After approx. 30 min. of walking on full speed it stops abruptly. The display shows error L5. What does L5 code mean?
  • Anonymous Mar 21, 2014
    WHAT DOES 1 CODE MEAN
    Problem Solver:
  • 6 Answers
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Posted on Jul 29, 2009
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
TREADCLIMBER tc5000 error code L5
Step 1:
see the comment. and fix it. Run the software calibration.
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board. Refer to the proper flowchart.
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 06, 2013 | Bowflex TreadClimber TC5000
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Jan 22, 2011 | Bowflex Treadclimber
I have an L5 error on the display. Belt not working. What do i do?
This is a LS or speed sensor error, it can be caused by a belt that is too tight, non lubricated walking belt and or a bad sensor. If the belt does not move at all, Bowflex will tell you to buy a new lower control board. $227 direct from them (Nautilus)
Jul 19, 2010 | Bowflex Treadmill Series 7
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
My tc 3000 makes a loud noise and I get an err l5 on display screen
not sure about the loud noise but my issue with the l5 error was a simple adjustment to the speed sensor.. take of the left and rear covers, then look for the sensor that goes into the red grommet attached by 2 wires. slide a business card in between the wheel and the red grommet.. then make sure the speed sensor is pushed all the way against the card and then remove the card. that solved mine :)
Jun 30, 2009 | Bowflex TC3000 Treadclimber
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex Treadclimber Logo
2,687 people viewed this question
Top Bowflex Exercise & Fitness Experts
Jerry Greenberg
Jerry Greenberg
ptpumpman
Jesse Garza
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
