posted by big_dee78 on Nov 15, 2007
i have a LA SOUND CAD3000 amp. but when i connect it a light comes on on the amp where it says clipping and then goes into protection. can u help me out. thanx
Solution #1
posted on Nov 15, 2007
It sounds like the amplifier has shorted output transistors. The clip indicator may be on because the output is equal to the rail voltage. The amp is probably going into overcurrent protection when the drive circuit engages. The amp will have to be repaired. If I'm not mistaken, this amp uses the dlogixs modules. Since the modules are not readily available, you may have to send it to an authorized service center or back to LA sound.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for L.A. Sound T475 Car Audio Amplifier
Email this problem
Email this problem
Can you Help with these Car Amplifiers problems?
Repair Service
Find Car Amplifier Repairman Near You:
