Question about Lexmark X3470 All-In-One InkJet Printer
Cover open it keeps saying cover open when its not and i keep finding solutions that are not helpful but maybe with more description and some pixs to help me i will be so happy if you can help please comment for my email and i will be happy give it to you. THANKS
  • 2 more comments
  • Rovita Dec 03, 2007
    Hi, Approximately 2 weeks ago I replaced the ink cartridge and since then it says "Cover Open" and it is not. It does not shut off unless I unplug it so what do I do?
    Susie McIntosh
    Just tried to take scanner part off but can not. What to do?
  • manny216 Dec 18, 2007
    Hey I was wondering if anyone can help me. My printer says "cover open" when it's not. Nothing works not even the power button the only way to shut it off is by unplugging it. Can someone please help me ?
  • tmorris Dec 24, 2007
    changed ink cartrige and now shows cover open & won't cut off unless i unplug it. nothing is open on it. what do i do?
  • Lexmark Master
  • 1,113 Answers
With the help of google here is your answer
Your arm of cover sensor has fallen off'
It is the switch fallen to bits
This switch
THis bit falls off
How yours looks
How it should be, or can be if you put it together again.
It might be possible to snap the part back on without partial disassembly, or simply shove something in there to hold the sensor in the 'closed' possition (If you lose a finger or two using this method, don't blame me)
The lid sensor is a tiny microswitch that is on the main circuit board...there is a white nylon lever arm snapped onto the switch.
if the lever arm falls off (like mine did) the 'cover open' error will last forever.
This may (or may not) be possible do fix without some disassembly. This lever arm should stick up through a rectangular hole that's approximately 1/2" to the right of the print head (assuming print head is parked in the middle) and behind it.
Most likely if your lever arm has fallen off, shaking the printer gently upside down with the cover open will allow it to fall out.
Now if you are a dentist or a surgeon, snapping the lever bit back on is no problem without taking anything apart.
I am neither. For the brave (of foolish) ones who like to do surgery, here goes. Here's how I took mine apart....if yours breaks into a million bits, don't blame me.
0) unplug the power and take the scanner cover off.
1) release the 'kickstand' from the scanner by prying and squeezing it with pliers until the two prongs pop out (or crack and break)
2) detach the scanner hinges by prying/squeezing with pliers until they pop off (or crack and break). (CAUTION: read step 3 below first...don't just yank the scanner off without reading step 3)
3) Carefully unplug ribbon cable and other connector to scanner and set scanner aside.
4) remove screws at front of beige plastic part....pry at the back carefully and this will pop off....sending the screws flying if you left them loose in their little wells. Don't worry, there are only two of them that really do anything anyway.
5) Look towards the rear of the printer and you will see the circuit board and the 'hole' where you can see the sensor, and possibly your white nylon lever arm lying pathetically down in the bowels of the printer.
6) Retrieve and Carefully snap the nylon lever arm back on, and think nasty thoughts about the brainiac who designed that part.
reverse the above steps. Put at least most of the screws back in, or the front panel may fall off at a later date.
Take care to GENTLY plug the ribbon cable and the other scanner connector back in, making sure it's seated all the way. Try not to bend or kink the end of it, or it will be toast.
Good luck, and happy lexmarking.....
Posted on Dec 28, 2007
Hey whats the # to call the office
Posted on Dec 22, 2007
Call your lexmark office and discuss the trouble ..
I was sent a repaired one at no cost for frieght either way
Posted on Dec 20, 2007
X3470 printer,installed new all-in one inkjet and now all apears is
cover open and power will not shut unless i inplug printer,all started with new ink cartridge heed help
Posted on Dec 16, 2007
How do I delete pix of unwanted people?
Simple. Block them or keep your account private. Find out more here... Facebook Help Center Facebook
Jul 24, 2015 | Facebook Instagram
When using Acronis Drive Monitor it says the hard drive is above the warning level. It says SMART is good. I opened the cover and left it open and I see the temp went to 111 and now its at 109. Is there...
simplest solution is to add another fan to **** the heat out of the machine.or just ignore the warning as most hard drives can handle the heat in the casings
Aug 16, 2011 | Dell Inspiron 530s Desktop Computer
My mx 300 keeps saying paper jam. i cant find any paper in it , iv tried turning it on n off. iv tried uninstall ..
Hello thanks for using fixya
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon MX300 Office All-In-One Printer
I'm tyring to print but it keeps saying "cover open" although no covers are open
there is a sensor that check the door
it is under the cover try to find it
and put some paper in the hole that the sensor is paced there
May 20, 2010 | Samsung ML 1610 Laser Printer
Lens cover problem SE w700i
I own a Sony Ericsson w700i phone.When i go to camera i open the lens cover and it says "open lens cover" while it's open.What should I do?
Feb 13, 2010 | Sony Ericsson W700i Cellular Phone
My camera won,t let me put more pictures on,it keeps saying memory card full,and i used to be able to store more pictures on it
FIRST check out the settings of camera , example , 3 mp 200 pix capacity , 5 mp 100
pix capacity , the higher the MP , the less pictures capacity , hope this helps , AJ
Jul 14, 2009 | Cameras
I keep getting the " covers open " on my dell 926 printer. help
sensor or switch not working or sensing find and figure out why not working maybe dirty blow out with compressed air!!!!! :)
Jul 06, 2009 | Dell 926 All-In-One InkJet Printer
Vista/cant hook up disney pix camera cant find driver?????
I have a camera...
So first you connect the cord to the camera then to the computer tower.
Then you Take out the disk.DO NOT LEAVE IT IN!!!!!!!
wait for it to load then when it does you'll have to click next,next,then finish.
In a few days go to the file you loaded them on.
then insert the disk and click burn pictures
I would ask someone like a specialist to see these directions before you proceed
Jan 20, 2009 | Disney Pix Micro Digital Camera
Canon PIXMA IP4500 (printer) won't install properly. I followed all the correct steps up until it asks to perform a "Print Head Alignment", I click "EXCUTE" and it keeps saying the top...
it may be because of the sensors. try to clean with sensors or maybe because the sensor wont reach its bottom, that is why the printer always recognizes that his cover were always open... try to push it hard..
May 27, 2008 | Office Equipment & Supplies
Can't recive or send pix messages...
take the phone to your mobile service provider or call them so they can set up the phone on the network for you.
Mar 24, 2008 | Motorola Mobility RAZR V3
Lexmark X3470 All-In-One InkJet Printer Logo
128 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
