Question about Sylvania 6620LG 20 in. EDTV-Ready LCD Television
DTV???????????????????????? DOES MY SYLVANIA 6620LG TV HAVE A BUILT IN DIGITAL TUNER OR IS IT DIGITAL READY? OR WILL I NEED THE CONVERTER BOX IN FEB 2009? I CANOT FIGURE IT OUT.
  • Anonymous Dec 24, 2007
    I have an LG 26LC2D LCD TV....according to the adds when we bought it, it has the "ATSC/NTSC/QAM Clear Tuners" but I can figure out how to get the signal. The Menu option to check the signal is greyed out and I can't select it. The only thing I can find in the owners manual is "Digital Signals: Only when the input signal is DTV or CADTV , this function is available." I'm not really electronics savy so I'm not sure what that means? Anybody help???
  • 934 Answers
From the side of the carton in which it came:
CONSUMER ALERT: This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009 to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322), or visit the commission’s digital-television Web site at: www.dtv.gov.
The only other thing I could add to this, is that the Post Office in 2009 will get the task of handing out $40.00 coupons to to anyone wishing to purchase a converter.
Posted on Nov 15, 2007
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Want to Know if my TV is a DTV
it most probably is DTV ready, try googeling some on the subject, but since its a LCD tv from 2006 its most likely to made with a digital tuner. Note : if you have cable or satelite ( dish networks, Direct Tv and so on ) you are allready watching digital TV and do not need a converter box.
Mar 05, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
DTV
this set should have an atsc tuner built in and should pick up the digital stations with no problem over the air
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Converter box
if you do not have cable, fios or directv you will need the converter box
Oct 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
SANYO DS31590 TELEVISION
No digital tuner inside. Will have to have a converter box in Feb 2009 for digital: Search "the fcc on digital tv transmission" on the internet for useful information on the upcoming digital age..
Dec 22, 2007 | Sanyo DS31590 31" TV
Open Questions:
Sylvania 6620LG 20 in. EDTV-Ready LCD Television Logo
335 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
