Question about Toro Lawn Mower With Toro Power Tools
Zero turn runs for approximately 10-15 minutes and then stops running.
    President:
  • 948 Answers
We need more information Henry. If it acts as if it is running out of gas after that amount of time I would check the gas filter, gas tank vent, and air filter.
Posted on Jul 11, 2009
My dehumidifier doesn't stop even if you turn the knob down to zero
Turn the knob the other way - you are most likely setting the target humidity closer to zero, which would cause it to run more (or constantly).
At a higher target humidity it will run less. You should hear a distinct click as you turn it higher - that is the current humidity in the room, and the compressor will shut off. The fan may run a little while longer, but should shut off as well in a few minutes.
Good luck and please rate this answer 4 stars if helpful.
Oct 25, 2017 | Dehumidifiers
My neighbor changed the steering wheel on a 2001 suburban and now security light is on. Now the truck starts then dies. I need a passlock diagram
Sounds like you need to do a 30 minute security relearn. Basically turn the key to the run position, do not start. Leave it in the run position for approximately 10 minutes. The flashing security light will go out. Turn the key off for 5 seconds. Turn it back to the run position for another 10 minutes. Again the light will stop flashing. Tune the key off and repeat one more time. When the light stops flashing turn the key of and then start the vehicle.
There are also plenty of references to this online as well. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 22, 2015 | Cars & Trucks
My 2004 Honda shadow vt600 vlx quits running after approximately 10 minutes of riding. It just shuts off and won't start. Has a new battery, plugs and changed oil & filter. What will fix this prob
How does it quit? Just suddenly stops, or coughs and sputters (probably gas), or gets jerky (ignition). Does it run just fine and then just stops, or does it run crappy and then stop? How long do you have to wait until it starts again? Is there a choke? Do you turn it off?
Sep 27, 2014 | Motorcycles
1994 chevy kodiak with Cat 3116. Heater/AC blower shuts down
you should make a diagnostic to know what happened to your car
of course you need an auto diagnostic tool : http://www.chinasnoy.comand you can find all kinds of tools in chinasinoy.com
May 21, 2013 | Cars & Trucks
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Toro Lawn Mower With Toro Power Tools Logo
41 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
