Question about Epson Stylus CX4800 All-In-One InkJet Printer
How do you get ink cartridges out -I have it open. catridges are in middle but I don't see where you can release them
  • 3,741 Answers
You just have to open the printer cover.the cartridges with the box will come in center.then you will have to slightly open the front of the box there will be a slight holding lock.then simply lift the required cartridge out.lift the cartridges towards up. thanks.
Posted on Jul 11, 2009
How do I insert the ink cartridge
power on the printer, open the catridge door. after printer initializes the catridge carriage assembly comes to right side of the printer and settles then insert the catridges and close the door.
Oct 17, 2014 | HP Office Equipment & Supplies
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
How to change ink cartridge
There should be a Lid you can lift up (where the paper comes out after being printed on) and when you lift that up you will see the ink cartridge move to the middle, Where you can push the open switch and replace the ink catridge. After the ink is replaced, lock the ink cartridge holder, and close the lid. You then should be ready to print.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 24, 2010 | Brother MFC-5440CN All-In-One InkJet...
Just replaced the color cartridge to my Epson Stylus Photo 820, but it keeps telling me the [New] cartridge is out of ink, or that there is a connection issue. The middle light is always on and red. I've...
try to clean the pinout of ur catridge also for ur printer cartridge mount (when ur printer is off) with cotton and Acitone if this not worked try to press and hold on power button or release button or the two buttons together for more than 15 seconds to reset it
Jun 17, 2009 | Epson Stylus Photo 820 InkJet Printer
Have to replace catridge
hi, with the printer on just lift the lid the cartridge carriage will park it self in the middle of the printer the just remove the cartridge and replace with new cartridge after undoing it and removing the plastic cap over the ink outlet
Mar 10, 2009 | Canon Office Equipment & Supplies
The catridge cover goes to extreme right so that i cant fill in the inks
u first open ur printer top cover its automatically the cartridges will come to middle (or) in system go to printer option in douple click there is some options like vlack and tricolour just click it follow the rules
Aug 26, 2008 | Epson Stylus Photo R260 InkJet Printer
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Hp psc 2110
there are 2 catridges. You need to lift the top half of the machine (the rlease is wehre you put the paper in), the catridges will come to the middle position, then simply lift the clip and remove the cartridge
May 03, 2008 | HP PSC 2110 All-In-One InkJet Printer
Streaks down middle of and rainbow colors on top of printed pictures
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
or you can use a hot water to clean surface of your catridge
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartridge
I would turn on the printer, raise the cover to get the catridge swing to the middle, then take off the power cord to have the catridge stay accessible. Gently push from the sides or bottom and slide it on the right track. when you're done, close the hood and re-connect the power.
Oct 23, 2007 | HP PSC 1610 All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
