Question about Cuisinart Brew Central 12-cup Coffee Maker
My cuisinart coffe maker takes a half an hour to brew 8 cups. What can I do to speed it up?
  • 85 Answers
Hello klj9,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, klj9. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
Brew group/thermostat ?
Definitely sounds like an overheating issue. Especially if you have to wait a half hour for it to cool down and then it brews again. If it is under warranty I recommend replacing it.
Jan 24, 2014 | Saeco Vienna De Luxe Espresso Machine
Only brews one cup at time
Open this website and choose on the right side "DOWNLOAD USER MANUAL"
http://www.cuisinart.com/parts/coffee_bar/dcc-2000.html
Jan 13, 2013 | Cuisinart DCC-2000
How do I clean my coffee maker?
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
How do I clean my coffee maker? I have very hard water.
i have a Cuisinart also and this is what i do: fill the resevoir with white vinegar and start the machine. once it has started through, shut if off for about 2 hours, then start it again. do this a couple of times using the same vinegar. afterwards run about 3 pots of cold water through to rinse it out, this should help clear the pumping tubes inside.
Nov 12, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Nov 15, 2008 | Cuisinart Coffeemakers
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
322 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
