Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU43 My Bosch SHU43C dishwasher stopped washing, turns out the impella came free from the motor, I repairded impella and put it back together and now the dishwasher washes great however now it is stuck in a wash rinse drain cycle. Display counts down but the unit never stops running when it reaches 0. Also, the water level is higher than normal and I there is a kind of thumping sound repeatedly every 15 seconds " use to make that sound only once at the start of a cycle before the impella broke. I have tried canceling cycle per manual but there is no change. So I am running the dishwasher for 45 minutes then turning it off manually, letting dishes dry. Machine is 3 yrs old. "Last Bosch I ever purchase" hope you can help. Thank you!
    Problem Solver:
  • 7 Answers
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Posted on Jul 23, 2008
BOSCH SHX46A06UC DISHWASHER WATER IS COLD, DISHES ARE FILTHY
We had this a while back - it was something to do with a blocked filter right inside, which meant the hot wasn't coming on. The repair man had to put in a new filter, which had been blocked possibly cos we had been doing quick washes with environmentally friendly detergent, and that solved the problem.
Jan 21, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher sounds like it has a grinding noise when it is first turned on and through out the cycle.
you have a wash pup seal failure water will enter motor bearing causing metallic wine new motor and seal kit will be needed.
Jan 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
May 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher
These push on to the hinges with the angled side pointing outwards.
Mar 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
422 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
