Question about GE WSM2700D Top Load Stacked Washer / Dryer
GE DSXH43GAOWW stackable dryer makes loud squeeking noise when turning. Cannot find drawings anywhere to take apart and look at problem. Any ideas?
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
  • 3230 Answers
SOURCE: Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Posted on Mar 28, 2009
SOURCE: ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Posted on May 11, 2010
dr appliance
  • 266 Answers
SOURCE: ge stackable wsm2700dawww
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
Posted on Jan 24, 2011
Loud squeeking noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfjsf
Sep 21, 2010 | GE DVLR223 Dryers
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2009 | GE Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE dryer is getting louder and louder - not a squeek just motor seems to be running louder
THERE ARE THREE POSSIBLILITY. THE BLOWER WHEEL IS LOOSE AND BANGING ON THE VENT. THE BEARING FOR THE TUMBLER IS BAD, MAKING A LOUD SCRAPING NOISE. ROLLER BEARING IS BAD. WORSE CASE, THE MOTOR IS GOING BAD. GOOD LUCK
BOYNISMO@YAHOO.COM
Jul 04, 2009 | GE Dryers
Squeking noise
Here is a handy GUIDE
Jun 26, 2009 | GE DBSR453EBWW Electric Dryer
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a kenmore stackable washer and dryer and the dryer squeeks really loud it drives me crazy and makes it hard to do my clothes
depending on the age and the usage of the dryer, it could be the belt, or the bearing that the drum rotates on
Jan 14, 2009 | Dryers
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE WSM2700D Top Load Stacked Washer / Dryer Logo
141 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
