Battery was flat , hooked up jumperleads and indicator lights came on and stayed and wont turn off
SOURCE: vw golf 1994 indicators
Most Golf and Jetta have their relays bunched together with the fuse block. Often, it would be inside the fuse box/compartment located under the facia panel, on the right-hand side, behind a removable cover. On most models, the flasher relay would be labeled 21.
Incidentally, sometime ago, there was a recall on some Golf where Volkswagen dealers will install a new hazard flasher switch/relay kit to remedy a common issue. You may want to try first Volkswagen at 1-800-822-8987.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Ignition key turns on but car will not start
I suspect the ignition switch is malfunctioning.
SOURCE: location of turn signal flasher for 1997 Buick skylark
the flasher is behind the dash where the steering column goes. It's hard to get at and harder to remove. They just can't make these things easy, can they?
SOURCE: no brake/hazard lights,have running/turn signal lights
Suggest you change hazard flasher 'can' first, then go to the hazard switch. I'm betting it's the flasher can.
SOURCE: indicator lights stay on perminently
its the signal switch on the colunm NOT the hazard switch
