Question about LG Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not finished. If we play around with the machine, unplug, open and close door, reset, change programs, etc. it will sometimes start to work. The machine seems to always gives the code at the rinse cycle portion of the cycle. This time the machine just kept turning the load in the rinse cycle,it was stuck. After we stopped the machine the dE code came up right away again. Another time the dE code was on the machine when we went to check on it. It again was in the rinse cycle. We pressed the power button and a PF code came up. Pressed the start button and the machine restarted in the rinse cycle. The consistent things seem to be dE code comes on in rinse cycle and stops the machine cycle. After that how the machine gets restarted by us seems to be a crapshoot.
  • 6,784 Answers
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
  • ngahiriwa Aug 31, 2013
    weres the pwb/
How do I trouble shoot the error code on my LG Tromm WM0642HW, it is an upside down F and E.
could the upside down F be a lower case t. If so the error code is tE and you have a heating problem.
Jan 25, 2015 | LG Washing Machines
Lg tromm wm0642hw
I'm guessing it has a float switch that shuts the water off when its full, and if it were bad it would not stop filling. Until the float switch tells the valve to close its also is not going to tell the pump to come on.
Mar 21, 2014 | Washing Machines
Have WM0642HW washwer. Constantly getting dE code during each load. Hearing grinding during cycle just before dE display.
open the filter and you will find coins or some form of objects that has gone in to the wash by mistake unseen!! empty out the filter and put on wash and it will be fine! if there is water in the drum make sure you put bucket that will fit under filter to catch the water when opening the filter! or if there is a rubber tube you can drain water out from this till empty but this will take time! good luck and dont get wet
Feb 28, 2013 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
What does the dE error code mean
dE = door error. Most likely a door latch issue.
DE = drain error. Plugged filter or bad pump motor.
Apr 18, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
STARTING PROBLEM OF FRONTLOAD WASHINGMACHINE
If the error code is DE, then you need the door lock assembly.
I will need the full model number to find the right part number.
Mar 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
655 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
