Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Only hot water/ little pressure
My moen 3175 single handle is only giving me HOT water and no pressure
  • 20 Answers
You must of turned off your water to the house or maybe it was turn off in the street recently because it sounds as if you have debris in you strainer remove the head and rise of removing any dirt rise out both front and back of shower head while head is off run shower to make sure you are getting full pressure out of the pipe that the head is connected to
Posted on Jul 12, 2009
No hot water or pressure at shower head
check ur anti-scold setting when shipped from factory unit is set cold install instructions always advise about adjusting to suit your comfort--remove handle and using the blue & red adjustment tabs set the heat to your desired comfort
Mar 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My(installed today) moen single handle shower valve (82910CBN) is only producing cold OR hot water. It is not mixing. What should I do to fix this?
if u still have instructions it will explain how to adjust the water -in the handle are a red and blue plastic tabs that are adjustable pull back and turn to adjust --this is the anti-scold--till u are satisfied
Nov 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Th hot water side of single handle shower faucet does not work, cold side works
most likely it is the cartridge,if you replace it this may fix this problem.you must remove the handle and a pin at the top of the cartridge,first make sure the water is off to the unit then proceed.
Jul 29, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle shower no hot water.
when shipped the anti scold is in cold mode remove center handle will c a blue and red adjustment pull red off and move up or down and replace check for desired temp if cold or to hot readjust
Jul 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough hot water
The screws remove the handle. After the handle is removed their are little plastic like gears to limit th ehot watr. Relocate the gear ring for more hot water.
Jan 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
279 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
