05 astra air con fault
Hi,got an 05 petrol astra,the air con pump isnt cutting in,have had it running with a power probe,but its lost its live feed,anyone know what relay operates it?or any commomn faults?have checked all fuses,and done a continuity test on the live feed as far as the fuse box under the bonnet.be very apprciated.sam
  • 73 Answers
Hi there. The compressor will not come on unless the system is charged. There is a "low limit switch" which controls the engage voltage on the low side receiver. No charge, no engage.
Thanks
Paul
Posted on Jul 11, 2009
Im driving an opel astra j essentia 1.6 2011 model,recently it started jerking or cutting petrol supply, i bought a new petrol pump the problem still persists please assist.
Jerking or cutting fuel supply? How did you determine that? This is most likely a sensor in the engine. Could be a fuel pump relay but it most likely is a crank shaft sensor.
Jan 27, 2017 | Opel Cars & Trucks
I have an LG split system air conditioner model number LSZ244VN-4 it is coming up with a fault code of CS after it has been running for approx 5 minutes
There is no CS code. Please read as C5.
Fault Code 05 and 53 (CH05 is displayed at indoor unit, 53 is displayed at outdoor unit)
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
Testing
• Check Outdoor and Indoor Power Supply Voltages ( 230V ±10% ) and correct as necessary.
• Check for any mis-wiring or loose connections and correct as required.
• Check the resistance between communication line and GND. (Normal: Over 2M).
• If one Indoor unit operates normally Outdoor PCB is generally normal.
Turn on the power and start the indoor unit in cooling, set the temperature to 18ºC; the serial communication
signal will only be present for the first 3 mins of operation.
Set your meter to DC Volts, Test between terminals 5 (Red probe) and 2 or Earth (Black probe) of the outdoor
unit, you should see a fluctuating 0-72 Vdc.
If the Voltage is not present disconnect the terminal 5 cable, test the Voltage between this wire (Red probe)
and 2 or Earth (Black probe), you should see a steady voltage in the range of -0.1 to -10.0 Vdc. If No Voltage
is present either the cable or Indoor PCB must be faulty. This can be determined by checking the voltage
output on the Comms terminal of the Indoor unit, with the Comms wire disconnected. If No Voltage is present
the Indoor PCB must be faulty, if present, cable must be at fault.
Jan 19, 2011 | Heating & Cooling
I have a LG Inverter Art cool and after about 5 minutes it stops and C5 shows on the panel Kerrie
Fault Code 05.
Testing
the Indoor PCB must be faulty, if present, cable must be at fault. Helpful?
Jan 19, 2011 | LG Art Cool LA121CNP wall/window Air...
1994 Kawasaki ZZR-400 Leaks oil and doesnt start sometimes.
that box is called the air box, its where you engine breathes in its air. you say its leaking oil? these boxes are normally a bit oily but only really surface oil. If you can actually see liquid oil you have a problem with your petrol shut off. When the bike isnt running petrol will leak into the engine through the piston. When you start the bike all the petrol mixed with the engine oil will be pumped back into the air box. also check the level of the engine oil, if too much has been put in there then that can also be pumped back into the air box. If the petrol and oil has been mixing you must change the oil as petrol thins the oil and your bike could catch fire, the engine wear will be really bad.
Aug 29, 2009 | 1994 kawasaki ZZR 400
I started my 2002 golf and it cut out then and lost all power
HI,SOUNDS LIKE THE MAF SENCER/ AIR FLOW METER HAS GONE FAULTY, BEST THING IS TO GET A SCAN DONE THAT SHOWS THE FAULT,THANKS.
Apr 17, 2009 | 2002 Volkswagen Golf
Ford probe
The fuel pump is very small and located in the fuel tank, these pumps are cooled by the gas around them, if you run out of gas it will overheat and many times fail, this is common.
Oct 17, 2008 | 1994 Ford Probe
Air con only works for 5 minutes then goes warm on my jaguar x type 2.0 petrol 2003
Hi, it sounds like an undercharged condition.Locate your ac compressor and watch the end of the pump shaft(clutch).If the clutch isnt turning while it is blowing warm,check the pressure in the system.Low charge will cause the clutch to disengage.It does this because the pressure switch isnt meeting the requirments to close the circuit to the compressor clutch..Good Luck!!!Dont forget to rate my answer...Thank You
Aug 04, 2008 | Jaguar X-Type Cars & Trucks
Vauxhall Astra LPG, fault
i hae got the same problemm has above have ben told that it is a loose wire cos does not isfire all the time just every so often
Feb 23, 2008 | Baby Gear
Heating & Cooling Logo
499 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
