Error Message : Open heat error cycle power -not printing
  • 19,396 Answers
Open Heat Error Cycle Power error on Samsung, Dell, and several re-tagged laser printers means that the fuser (heat) circuit is open.
faulty parts can be the Fuser Lamp, the Fuser High Voltage circuit board, or the Fuser thermistor.
All this parts are located in the area below the toner. Parts must be tested using a multimeter to find out what is faulty.
Unless you are a repairman, all you can do is unplug power cable for one hour, and allow the printer cooling down.
If the problem is still there when you plug back the printer, call the service number listed on the owners manual and arrange a repair.
Regards.
G.
Posted on Jul 11, 2009
SOURCE: Open Heat Error
I was gettng dirty copies and a Dell Rep suggested I needed to replace fuser. Ordered a new one, installed it with Dell's help and the "open heat error" started up. We then put the old fuser back in and the same problem continued...."open heat error". I'm wondering if something else may be in play...I've unplugged, replaced and started over but none of it helps. Perhaps there is something that needs to be reset, etc when installing this part. I did not have this error until I installed the new fuser.
Posted on Oct 02, 2007
  • 1003 Answers
SOURCE: Error message
OPEN TOP COVER CLEAN ALL RUBBER PAPER FEED WHEELS WITH RUBBING ALCOHOL APPLIED TO A MICROFIBER TOWEL.
THEN LOOK AT CARRIGE BAR THE BIG SILVER BAR THAT INK CARTRIDGES RIDE ON APPLY TWO OR THREE DROPS OF 3 IN 1 OIL AND TOP THE TOP OF IT AND RESTART PRINTER
Posted on Jan 17, 2008
rockfixya
  • 679 Answers
SOURCE: open heat error
"Open Heat Error" Means --- You need to make sure the voltage of the fuser is compatible with your printer.
Please rate the solution.
Thanks for using FixYa.
Posted on Feb 09, 2009
Aneesh AM
  • 56 Answers
SOURCE: led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Posted on Apr 24, 2010
  • 10406 Answers
SOURCE: I have an "Open Heat
>> Cycle Power.
Turn the printer off.
Disconnect the power-cable from the wall AC power outlet.
Wait a few seconds.
Reconnect the power-cable.
Turn the printer on.
That is one "cycle" of the power.
Posted on Oct 15, 2010
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
How to cycle the power on a Samsung CP610ND?
Pull out the plug, wait five minutes, replace plug and switch on.
Jan 07, 2014 | Samsung CLP-610ND Color Network Laser...
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Message on printer is "Open Heat Error - Cycle Power"...what does that mean?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 25, 2010 | Samsung SCX-6322DN All-In-One Laser...
"Low Heat Error Cycle Power" message. Faxes won't print.
Apr 06, 2010 | Samsung SCX-5530FN All-In-One Laser...
PRINTER NOT PRINTING ERROR MESSAGE : OPEN HEAT ERROR CYCLE POWER
This is the problem of the fuser unit. You may get it repaired/changed . Also you may approach Authorised servic ecenter.
Jul 25, 2009 | Samsung ML 4551NDR - printer - B/W - laser
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error message
Jan 17, 2008 | Epson Stylus Photo R340 InkJet Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
319 people viewed this question
k24674
Marvin
Marvin
