Question about Dryers
My Kenmore 90 series dryer runs but will not heat
My Kenmore 90 series dyer runs but will not heat up. How do I get to the heating element and fuse?
    President:
  • 1,730 Answers
Watch the video:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 11, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Kenmore 90 series will turn on but no heat
this dryer has a fuse kit on the heating element remove the back from the dryer the heating element is on the right you will see two fuses one just above where the wires plug onto the heating element one at the top of the heating element you need to remove the wires from these and check with a meter if either one these are bad you need to replace both
Sep 06, 2009 | Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmore dryer 90 Series is not heating.
This sounds like it could be the thermal fuse or the heating element. You can check the thermal fuse and heating element for continuity with an ohm meter. No continuity would be bad. The fuse is usually located close to the duct. Hope this helps.
Jul 16, 2009 | Kenmore Dryers
We have a kenmore dryer model 11068934792 ser. mj3303110 -90 plus series we do not get any heat when it is running
It sounds like you have a bad heating element or thermal fuse. The fuse cannot be reset. If it is bad, then it will need replaced. Often a dryer heating element burns out, but doesn't triop the circuit breaker or blow a fuse. The heating element is simply a long coil of wire. You can check it for continuity with an ohm meter. No continuity means that the element is bad and you will have to replace it. The elements are not repairable. Hope this helped.
Jul 16, 2009 | Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2009 | Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
340 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
