Question about Achiever CCS-1500 Cross-Cut Shredder
Ccs-1500 The light is flashing at all times and beeping. What could be the problem. Is there a manual I can download?
The solution is to remove the paper bin, and dig out the jam.
1. Unplug shredder
2. Remove paper bin
3. Lay it on it's side or back
4. Dig out all the paper around the teeth
5. Put paper bin back in and plug in
6. Should be good to go
Posted on Sep 16, 2008
I turn it on. Beeps 6 times. 2 lights flashing. how do I solve this problem?
Your problem might be a bad keyboard. The service manual says to check the ends of the cables that attach the keyboard to the system board. You may need a technician to swap a known good keyboard with yours and see if that is the problem. If it doesn't work then you will need a new system board.
Jan 12, 2016 | IBM Wheelwriter 1500 by Lexmark Electronic...
Fix this shredder
The unit is probably clogged up with a bunch of shredded paper. Unplug it ! Clean out the paper using fingers and a knife to get most of the paper clips and paper out then plug it in and run forward and reverse. That's what i do and it works every time.
Nov 16, 2013 | Achiever CCS-1500 Cross-Cut Shredder
You unplug it and clean out all the junk clogging up the works run it in forward and reverse a few times should be fine
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
When I turn on my Wheelwriter 1500 it beeps 6 times and the lights flash and the keyboard is frozen. It does not let me type.
Many possibilities. Look on and under the PC board for debris especially metal, The next most likely is the keyboard.
Aug 06, 2010 | Lexmark Wheelwriter 15 Series II...
Go to this site for help on light/beep codes.
Mar 06, 2008 | Citizen CBM 1000 thermal Printer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Achiever CCS-1500 Cross-Cut Shredder Logo
316 people viewed this question
Top Achiever Office Equipment & Supplies Experts
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
