Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
My ryobi weed eater is idleing ok, but pulsates at full throttle
  • 437 Answers
A carburetor adjustment may help but not after you mix up some "fresh" two cycle mix at 40:1 ratio. This type of equipment may say use 50:1 mixture but does not have enough oil to keep cylinder lubricated. Thus you may burn up the equipment and wonder why.
Posted on Jul 20, 2009
  • 148 Answers
Have you tried adjusting the carb settings?
Posted on Jul 13, 2009
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    My Ryobi cs30 weed eater tends to shut off after I release the throttle.
    Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
    Sep 06, 2010 | Ryobi Garden
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Apr 27, 2010 | Ryobi Garden
    Ryobi petrol weed eater
    SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
    Dec 08, 2009 | Ryobi Garden
    Rhobi weed eater stalling
    Try spraying some carb cleaner into the intake while its running - with the air filter out..
    If that doesnt help & if it sat for a long time without being run - you might need to get the carb reuilt..
    Hope this elps !!
    rate me good ;o)
    Jul 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
    708 people viewed this question
    Top Ryobi Garden Experts
    Jim Parker
    Jim Parker
    Nick Olsen
    Gene Tuck
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
