Question about Kirby Ultimate G Bagged Upright Vacuum
Belt troubles My belt is not reattaching properly when I put the power drive back on.
    Problem Solver:
  • 19 Answers
Make sure the belt is on the belt lifter look in hole on back of head once head is locked on power plant turn belt lifter clockwise to put on shaft
Posted on Jul 15, 2009
How do I change the belt on a dirt devil dynamite II cyclonic
Hi! Happy to help with that. Please follow the steps below.
  • Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the three (3) screws.
  • Lift and remove brushroll. Dispose of old belt.
  • Slide belt onto motor shaft.
  • Place new belt in area of brushroll without bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end cap on the left is in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
  • Reattach nozzle guard by carefully sliding back into place. Interlock rollers and nozzle guard by tilting rollers down towards the base while replacing the nozzle guard.
  • Be sure to replace all three (3) screws.
Hope this helps!
Oct 12, 2014 | Dirt Devil Vacuums
Can't replace belt roller want turn after putting belt on
First make sure the belt is centered properly. If it's not, the belt will break before you've even used it. Depending on the model of vacuum, there should be a reset switch on the power head, or back of the machine.
Dec 20, 2010 | Eureka Vacuums
Belt is on roller. Not sure how and how to reattach
When you put the beater bar back in have the belt hook in the normal operating position. Hold the whole beater bar housing upside down and turn the hook. It will grab the belt. Once it does, keep on turning. It will get tough to do, but turn it until you can't go anymore. Then put it all back together!
Oct 29, 2010 | Kirby G5 Bagged Upright Vacuum
Burshes will not spin, filter is clean
Drive belt missing or not properly installed on motor or brush/beater? Perhaps foreign matter caught in ends of beater brush that are holding the brush tightly in place. Clean the debris away and hit with a little WD40, but not much. Make sure it turns freely by hand prior to putting it back into place. If the belt is loose, make sure it is replaced with the proper belt and installed correctly.
Aug 28, 2010 | Hoover Vacuums
Brush won't spin. Put it back on the ribbed belt
Make sure the driving motor (power on) is turning (without the belt attached). Make sure the brush turns freely when the belt is off (it's probably jammed with wound-up hair, thread, and other debris--remove the brush and clean/lightly oil the bearings). Check the tension of the belt which should be fairly firm--replace if sloppy. Rotate the motor shaft by hand when everything is back together and make sure the brush can be driven without the belt trying to jump off. Hope this helps!
Mar 03, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I removed the revolving brush to remove a jammed piece of debris I had picked up and after putting brush back, it no longer revolves
Reattach your belt properly and the beater will function.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Vacuums
How do I replace the drive belt on a kirby G4? Actually the belt is already replaced I just need to know how to reattach that front part back onto the main vacuum. HELP
Greetings from GoVacuum,
Here's a video we shot showing you in detail how to install a belt properly, and how to reattach the head properly. I hope this helps you;
Jan 30, 2010 | Kirby G4 Bagged Upright Vacuum
The beater bar won't turn
Your drive belt has come off, remove the bottom plate and reattach belt or replace it if belt is broken.
Sep 16, 2009 | Vacuums
How do you reattach the front end of a Kirby Heritage II vacuum cleaner so that the brush is engaged. ( Manual missing!)
you need to make sure the belt is on the roller correcty, make sure is at the red position when putting the part back on with the belt on the hook, push the pedal to highest (off the ground) position to ensure you put it on correctly, then turn the fixing clip thing to secure it, then once its on turn the panel around to green position, belt will be back on, once you get used to it you'll be ok,
May 08, 2009 | Kirby Heritage II Vacuum
Hoover windtunnel
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Jan 18, 2008 | Hoover U6616-900 WindTunnel Bagless...
Kirby Ultimate G Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
