Sure you can. (wind and gravity makes them all hard to find)
you cant even tell front rear, left or right side, or top side?
there are only 2 ways. (besides replacing all gaskets and seals.
1: clean it totally and see it leak , true location. (works for 100 years now... all engines, ask any mech, )
2; buy the UV dye kit and find it. like most folks do.
Good if you can see where it is you can fix it
SOURCE: 2005 Suzuki Grand Vitara 60k
best thing to do is call the dealer and get o.e.m oil to go back in it
SOURCE: Suzuki Grand Vitara Oil Filter Replacement Disaster
Four or six cylinder engine and behind or front of the oil filter? Looked under my GV 2007 2.7 V6 and can not locate a shiny metal box next to the oil filter. Only thing that was shiny was the exhaust manifold and oil sump which are quite hard to break or puncture. If it was the oil sump you will have to remove it and get it welded as a bog will not hold on heated engine parts.
SOURCE: where is the starter for a 2000 suzuki grand vitara located
starters are normally located at the rear of the motor usually hard to get too or see. should be on your bell housing in other words just in front of the gearbox/clutch
SOURCE: oil leaking from what looks like the harmonic balancer bearing
You need to pull the harmonic balancer and replace the seal... if i remember right it's a one peice press fit seal
Robert
SOURCE: After how many kilometers should i change the oil
you should change your oil approximately every 5000km
