Question about Boating
Boat 100hp took my boat to the lake this weekend,ran it out of gas and it will not run now,it looks like it is getting gas to the plugs not sure what i need to do next
  • 1 more comment
  • harley_marlb Jul 12, 2009
    i think it is in one of the coil packs,the guy i got it from put a new one on 1 side n the plugs r getting fuel i checked them today,so i am thinking it is a elec.problem but not sure how can i check to see.and yes i have a primer and i am not sure about the water seperator but will look if someone tells me where to.ty for your help
    if one of the coil packs goes out will it still fire
  • thomas foster
    thomas foster May 11, 2010
    do you have a primer bulb? and a fuel water seperator if so the fuel water seperator needs to be primed take it off and fill it with gas then try to start the motor u can tell if its a fuel problem buy tring to start the boat with starting fluid if it fires its fuel
  • 70 Answers
Remove one of the plugs, plug it back into the lead and holding the rubber lead, allow the spark plug end to touch the metal on the engine. Turn over the negine and check for spark. Repeat for the other plug.
No spark = faulty CDI unit, faulty coil, faulty stator
Posted on Jul 25, 2009
Need to chech how to fix my fish finder i check its power its ok but wont come on
Had a problem with my Humminbird. Took connectors out of cradle and ran direct into unit to check cradle, no difference.
Check your getting 12 volts of power to cradle. Did all this and ended up taking finder into a shop and plugging into their set up demo model and still nothing. Unit is stuffed, I'll replace it with similar brand to utilize cradle, wiring and sending unit
Apr 09, 2013 | Boating
Took RAV 4 to NC mountains and back twice this weekend. It ran fine but started it this morning and it would stall when I took my foot off gas pedal
I would change your fuel filter. The mountains, and the sudden jerking would provide a great chance for the fuel to pull up any nasties, and then run them through the line.
Dec 22, 2011 | Toyota Cars & Trucks
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Have 87 Evinrude outboard 48hp 2cylinder hesitations at high rpm ,but only very seldom like every few hundred yards cleaned carbs ,new plugs, checked spark, compression120 both cylinders newfuel lines new...
Make sure "advance/****** linkages are working properly, look for play and broken springs.
Check exhaust is not obstructed , may need cleaning.
Is fuel old or incorrect oil mix?
Mar 24, 2010 | Boating
I have 15 hp mercury hasnt been ran in two year tryin t sell when i first tryed to start it the motor would start run 1 to 2 seconds and die out thought primer bulb was bad went and bought new one then it...
my uncle told me to take the spark plugs out to check if they were dry and if they were to take a spray bottle and put gas in it and spray inside the pluggs and give it full throttle. The motor started on the seconed try.
Jan 15, 2010 | Light Outboard Motor Boat Bass Fishing...
I have a 150 hp outboard Mercury that is carburated. It has not been ran in more than a year. Boat had quit on the lake last April. Found bad starter. Had rebuilt. Put back on and was able to start in yard...
Did you put a fuel stabilizer in when you laid up the engine. If not varnish will build up in the system and clog the needle valves and jets. Use a good carb and injector cleaner to clear the jets.
May 14, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
