Acer Aspire 6930-6455 Notebook PC Logo
Posted on Jul 11, 2009
My bran new LG monitor has 2 hdmi ports but can't get a signal on either received from my 6930 hdmi out port??
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jul 12, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
7448
Points
48
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
I have a LG Flatron E2750v Monitor connected with a standard cord between the monitor In the center of the screen it reads: D-Sub out of range 68.5Khz/85Hz VGA Port or Power saving mode HDMI Port
Hi, that message indicates that your video source is providing an unsupported video resolution , please check in settings that video output resolution is no more than 1920 x 1080 @ 60Hz.
Also remember to verify that HDMI is selected as input source at monitor.
2helpful
2answers
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
I have had a 52" LG TV for about 17 months. I connect several devices (XBOX,CABLE,PC) through a receiver to the TV via HDMI. it worked fine all the time but now all of a sudden all I am getting is a no...
Did you change the HDMI cable? If so, you should check to ensure you have the cable installed so it is running the right direction. It may seem hard to believe but some HDMI cables only allow the signal to run in one direction.
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
1helpful
How can i watch tivo on my computer monitor
Sorry to say but no, your monitor only has VGA which is an analog signal and HDMI is a digital signal. A cable will not convert between the two. There are digital to analog converters available but they run more than a new monitor. You can use any monitor that has a DVI port with an adapter cable because the DVI port is digital just like the HDMI port so a cable can convert the plug between the two and the signal will then be the same.
1helpful
2answers
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
1helpful
2answers
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Can i use the dv port on my monitor to display a movie on a led tv? i bought a dvi to hdmi adapter and plugged into my monitor dv port and the hdmi cable into my hdmi port on my tv and i'm getting nothing...
Ports on the monitor are for receiving the signals from the sources, not for sending signals out to another devices.
Your TV HDMI should be connected directly to the video source output, not through the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
