These external drives have 2 components, the hard drive itself and the enclosure.
1. Listen to the drive as it turns on, do you hear any clicking or other abnormal sounds from the drive?
Clicking is a sign of a mechanically defective hard drive. If the data is super valuable a data recovery service can get it back, but they are very expensive. (Price depends on the level damage to the drive)
Ontrack is generally considered one of the best data recovery services out there. Another is
Drive Savers. I have personally met a few of the Drive Savers staff and have used them in the past.
There are a few 'home brewed' data recovery tricks from failed hard drives that are out there, but I don't recommend trying any of them if you are going to be sending the drive to one of these services. Sometimes they do work but in the end usually end up inflicting more damage to the drive making recovery more difficult.
2. If you don't hear anything, or anything abnormal the enclosure may have been damaged and your hard drive might be ok. The drive can be removed from the maxtor enclosure and put into a replacement one. The larger maxtor hard drives require the 'star' style screw drivers to bust into, I'm not sure what the portable ones need to get into. Be sure you use the right tools to take it apart to avoid damaging the hard drive.
Let me know and we'll go from here
Comments:
Nov 15, 2007
- Your local electronics store should have the hard drive enclosures. Make sure they know it is for a laptop hard drive. I know Best Buy, CompUSA and Fry's carry them.
That's actually a good sign that hopefully only the case has been damaged. If you aren't hearing anything from the hard drive the case probably isn't powering it.
