Question about Navman Tracker 5600 GPS Receiver
How do I link to a vhf radio (mt-500) so that the radio has the boat's position? Clearly I need a cable, which is the bit I don't have :-)
  • Allan Brehmer May 11, 2010
    Hello my name is Allan Brehmer and would like to put my Furuno vhf to my tracker 5600, I have a vhf NMEA IN - NMEA + and what colors should I put on the tracker 5600 and what to what? I come from Denmark
How do I Connect a Navman TO A VHF
Posted on Aug 16, 2009
How to connect the vhf dsc radio to navman 6500 trackfish
Your VHF needs to be compatible with "seatalk" (Alot are not) Generally the VHF and GPS/plotter/fish finder are two separate units on a boat.
May 04, 2018 | VHF Boating
Will i need to mount a separate fm antenna when i install my new radio this spring?
Hi!
Yes, you'll need a marine VHF antenna. They're widely available at any marine store. Hope this helps.
Happy Boating!
Feb 07, 2011 | Lowrance LVR880 Fixed Mount VHF Radio ()
On the ICOM M604 will not receive the weather channels, will receive other close radio's.
Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
Jan 09, 2011 | ICOM Informatique Icom M604 Vhf Marine...
Here's a good one for an expert. Our newish coastguard boat fitted with 3 VHF radios - all working correctly, recently had a wireless headset system installed. We get huge amounts of electrical nosie over...
From your info the GND & shield (could be the same) are crossed. or one is open. A shield as in the antenna coax or an isolated ground as in an internal type coax in the interconnect cable of the wireless headset assembly. I suggest doing a 'BOARD WALK' routine, Move the wireless assy from one VHF unit to another, the problem follows-bad head set assy. If not, return to original VHF, problem returns bad internal connection in VHF unit. Please let me know the outcome.
Oct 06, 2010 | Uniden Solara DSC VHF Marine Radio
With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Jul 14, 2010 | Uniden Solara DSC VHF Marine Radio
High Battery alarm goes off while boat motor is running
power supply for the radio taken from a source wire that is affecting the voltage regulation
take it in or have a radio technician come and check the installation
Jan 09, 2018 | Uniden Solara DSC VHF Marine Radio
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Oct 03, 2008 | Raymarine Ray 240 Modular Vhf System
VHF Radio
Check ther frequency tuning.
Sounds like it is off frequency.
Is the VSWR on the aerial Ok
Apr 01, 2008 | Raymarine Ray45VHF (53 Channels) 2-Way...
Any recommendations?
You can find a helpful guide at the following link:
http://www.boatsafe.com/nauticalknowhow/...
Have fun!
Nov 20, 2007 | Icom M302 VHF Radio
Navman Tracker 5600 GPS Receiver Logo
359 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
