Question about Samsung HC-R4355W 43 in. HDTV Television
Samsung HC-R4351W 43 in. HDTV Television issues. The tv will not turn on. My house was hit by lightening and since then the tv will not turn on. What would I have to look for or replace in order for it to work again? Or would it be more cost effective to get another tv?
SOURCE: Hitachi model # 51f510 television (house hit by lightning)
its worth fixing!!!just have a repairman
Posted on Sep 03, 2007
ctf1800
  • 4402 Answers
SOURCE: samsung HC-p4241w- replacement bulbs/screen
http://www.fixyourowntv.com/projectionclean.php
Posted on Jan 28, 2008
  • 6 Answers
SOURCE: replaced ics, no power
i have one on my workbench right now please check the jumpers you unplugged especially the one on the far left corner (goes to front panel) the one behind the stk 392 010 you replaced (very easy to miss)
take good lighting and make sure every jumper is plugged in
skip this if your set was working but if it wasnt check the fuses and fusible resistors
third if all that fails check your soldering make sure the joints(on the stk's ) are all good and shiny and the joints on the heavier components especially the line output transformer the big black plastic thing on the right of the stk ic you could have loosened it [UNPLUG THE POWER CORD FIRST]
Posted on Sep 20, 2008
Russmann
  • 203 Answers
SOURCE: Problems with Samsung HLR5067WX 50 in. Rear
Hi Ken,
Hope I can help you. Not only do I have the same set at home, but I've been repairing this equiptment professionally for 25 years. This problem can be caused by many different things. Mine has shutdown intermittantly for two different reasons. First, the shutting off was caused from airflow. The solution was to disconnect the power and remove and vaccuum the rear cover vents as well as internal fans. Careful not to touch the lamp.(Remove and set aside). When this problem occurred there were a few lights on the set that flashed.(Temp + lamp I think). The other problem that shut off the set on occasion was caused by the tv power supply.BP94-02222H. When it shutdown from this I could turn the set right back on without any problem and no lights flashed on the front panel. Also make sure to clean dust from the fan by the cable card slot. If this gets clogged a message will appear on the screen saying "Check the fan #3" I'm sure this is good, free and accurate advice. Good luck, Russmann.
Posted on Sep 09, 2009
saidneurot
  • 128 Answers
SOURCE: The TV made a pop noise and the TV shut down. I
here is this could wrokhttp://www.ehow.com/how_5535314_reset-lamp-hours-tv.html
Posted on Jan 15, 2010
My projection tv display got really dark a few days ago. I didn't change any setting before it happened, but I tried to change them today in order to lighten the display, but it didn't help. Could a...
Yes,most likely the projection lamp life are ending.The tv projection lamp been inside the tv like 1 1/2 or 2 years?Daily tv watches like 4 or 5 hours regularly?Yes,than the projection lamp life are ending,tv do need a requirement of a new projection lamp.
Jan 06, 2011 | Samsung HC-P4752W 47" Rear Projection...
The blue and green are fading into one color
The problems ur tv having is call convergence problems,it dead.Tv have mis colors lines R,B,G any parts of the picture,have colors shadows or 3D pictures look alike?The tv convergence board have dead parts 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the Tv convergence board to fix it to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Samsung HC-R4355W 43 in. HDTV Television
Electrical surge can we fix the tv?
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Tv won't turn on after repair
the first two things to check is to make sure none of the IC pins arent bridged with solder, and the other is to determine all wires are connected correctly and firmly.
Sep 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4741w flashing red light
That sound is made by the power supply who's gooing in protection mode due to some overcurent in secondary. Could be many reasons: conv. amp. IC's, video amp.IC's etc. In my opinion more then 70% chances to be the STK for convergence. Need to be troubleshooted by a tech.
Dec 07, 2007 | Samsung HC-P4741W 47" Rear Projection...
Samsung HC-R4355W 43 in. HDTV Television Logo
145 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
