Question about Rockford Fosgate T30001 bd Car Audio Amplifier
ROCKFORD FOSGATE T30001bd AMPLIFIER
I HAVE 2 OF THESE AMPS HOOKED UP TODAY I WAS PLAYING MY SYSTEM WHEN ONE OF MY SUBS STOPPED I TURNED OFF THE TRUCK AND CHECKED ALL MY ANL FUSES ALL WERE GOOD EXCEPT THE 300A ON THE AMP ITSELF SO I BOUGHT ANOTHER ROCKFORD 300A FUSE AND INSTALLED IT AS SOON AS I TURNED MY RADIO ON THE AMP MADE A LOUD POP AND STARTED ARCING OUT THEN THICK WHITE SMOKE CAME POURING OUT OF THE RIGHT SIDE OF THE AMP NERE THE FUSE WHEN THE SMOKE CLEARED I IMMEDATELY TOOK THE FUSE OUT AND IT DIDNT EVEN BLOW I REALLY HOPE SOMEBODY CAN TELL ME WHAT HAPPENED AND CAN IT BE REPAIRED I AM REALLY NERVOUS ABOUT MY OTHER AMP DOING THE SAME THING SO FAR IT IS FINE BUT IF I CAN PREVENT THIS FROM HAPPENING AGAIN I WANT TO CAUSE I THOUGHT MY SYSTEM AND MY TRUCK WERE GOING TO BE ASHES NOT A FUN EXPIRIANCE FOR ME THANK YOU FOR YOUR TIME PLEASE HELP ME!!!!!!!!!!!!!
    Novelist:
  • 111 Answers
If the amp is still under warranty, i would rma it. there is no easy way to tell what happened without opening the amp up, but from your description, it sounds like it fried the board, or at the very least fried some of the capacitors inside the amp (although the smoke would usually be a bluish white if this were the case). this seems to happen if you are running them at anything over 15-16 volts, i have seen two of these fry at 18 volts.
it could be something as simple as a shorted wire or trace at the fuse receptacle, but once again, your best bet if it is under warranty would be to rma it and ask them to let you know what happened to it.
Posted on Nov 15, 2007
  • Trinity Sabre
    Trinity Sabre Nov 20, 2007
    just following up on all of my "helpful" ratings, is there anything i can do to further help you with the problem?
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
2 12 p3d212 2 ohm hooking up to a rockford fosgate p325 .1 mono amplifier can it work? and how?
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
May 03, 2009 | Rockford Fosgate Power 501BD Car Audio...
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Fosgate T30001 bd Car Audio Amplifier Logo
266 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
