Question about Kodak EASYSHARE Z1285 Digital Camera
The lens won't retract. the camera no longer functions
  • 217 Answers
If dont mind i would suggest you to contact any expert or SERVICE CENTER because according to the problem you describe is technically difficult and due to jurk the gears of the zoom lens assembly may be broken misaligned, and there is a specific method to open the zoom lens assembly to change the gears, Or the if you want to repair it by yourself then you have to replace the complete lens block assembly, Therefore i would advise you to contact any expert for repair,
Posted on Jul 11, 2009
Lens won't retract on SD550
Try resetting the camera by removing the battery for 20 mins. then replace the battery go to the camera's menu and set the Date and Time.
May 28, 2012 | Canon PowerShot SD550 / IXUS 750 Digital...
My wb 210 got wet and now the zoom lens wont retract.
Unfortunately that isn't repairable. The most likely reason as to why the lens won't retract is because the water fried its circuit board and that is a costly repair.
Jul 26, 2011 | Samsung WB210 Digital Camera
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
Lens won't retract completely. Picture is blurry.
I wish I could offer some simple solution, but the lens has somehow gotten damaged and is no longer able to focus or withdraw into the camera body. It could be as simple as some sand in the lens, but even that will require a trip to a camera repairman
Sep 12, 2009 | Kodak EasyShare V803 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
Oct 01, 2008 | Gateway DC-M42 Digital Camera
Lens will not retract
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Ricoh Caplio R4 Lens
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
191 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
